andyvvc Posted February 22, 2010 Share Posted February 22, 2010 Had the Falkens fitted today. Lad who did the work was pretty small so seat was moved forward. I have reset to my position (further back). Noticed on drive home that the SRS light is flashin...I assume this isnt flashing to remiond me that i have airbags, but is actually flashin cos there is an issue somewhere...? I have the SRS reset procedure printed off (kudos to this forum!) but can anyone explain where the wiring connectors are under the driver side seat, incase i need to re-seat them? (Pun intended) Ta Quote Link to comment Share on other sites More sharing options...
SwanageDave Posted February 22, 2010 Share Posted February 22, 2010 I have the same problem everytime the wife moves the seat, it has never been the connections as when i do the reset it seems to work, which is switch on wait till it flashes turn ignition off straight away ..wait three seconds turn on wait till it flashes again and repeat three times in total and it should be reset, works for me good luck Quote Link to comment Share on other sites More sharing options...
AlexZ Posted February 22, 2010 Share Posted February 22, 2010 I had this issue aswell mate, I took mine to a friend who just plugged it in and reset it... The air bag wires are normally orange...just peep under the seat and you will see them... good luck. Quote Link to comment Share on other sites More sharing options...
andyvvc Posted February 23, 2010 Author Share Posted February 23, 2010 I did the reset this morning - the SRS light then flashed a LOT slower, but still flashed. So i turned the ign off, and fiddled under the drivers seat pushing wires etc. Nothing felt loose, but when i restarted the car the SRS light was gone Cheers all Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 23, 2010 Share Posted February 23, 2010 Will have been a loose connector. I dont think they are particularly good tbh given the amount of people that get them, just push all the connectors home and reset seems to work whenever the light does come on Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 23, 2010 Share Posted February 23, 2010 if not a loose connector it may be over time the seat loom as has become trapped against the seat frame and broken a wire. I had this happen. Simple to repair but resoldering the two bits together and ensuring that the loom is clear fo the frame in hte future. Cost £45 to repair at L&G Quote Link to comment Share on other sites More sharing options...
