cats and Y pipe dropped!! FIXED sort of!!!
sparky370z
i had an scorpion exhaust fitted with a Japspeed Y pipe yesterday.
however after driving about today it is touching and rattling on the beam that goes across the car about half way up the mid pipe. i have checked that the hangers are on but it just seem weird that it was OK yesterday but is now fouling.
also does the scorpion get "louder" when it gets hotter, ie when your driving harder? as when i was driving a bit harder than usual it sounded almost like it was blowing.
Cheers
Sparky,,,
Had the same fitted 2 weeks back and mine was doing the same... My mechanic was scratching his head at first until he tightened up the bolts in the mid section. This brought it well in to line and clear of the cross beam,,, its fine and dandy now....
Try doing that pal, I am sure it will sort out your prob.
Dave
Pipe is installed wrong just rotate it about 45 degree's who installed it?
local place mate,
what do u mean rotate it 45 degrees? u cant do that, its a flanged joint.
all the bolts appear to be tight as well. its a bloody pain really. they have used sealent on all of the joints as well. i just hope that they havent damaged the cats or even worse the manifolds, removing the old bolts!!
cheers
local place mate,
cheers
I would get it back there mate, and get them to sort it. Think Dan means the midpipe is on upside down perhaps?
You had it up on a jack?
no havent yet, will tomorrow tho, when i had a quick look, the cat seems to be low on the drivers side. there are no hangers there so i hope that they havent damaged anything when removing the bolts and the OEM Ypipe. my sisters BF (who is a mechanic) said to go there as they were not bad and have dont some work for him in the past. (RSR, factory lane, Croydon).
Bloody Knew i should have done it myself!!!!!
Sparky
Sparky
Ha! you were 5 mins away from me! had the ramps out and everthing today for mine! If you got OEM cats then they have hangers on them.. connect to a m shapped bracket in the centre...
Shouldnt have damaged, there are flexis there. Dont let them push and prod it. just ask them to remove the mid and try and refit.. Is it a new zorst?
sods law that!!!!
they are OEM Cats. when i walked over to have a look at what was happening i did notice a fairly large hammer on the ramp next to him!!
i had the Y pipe, mid and box installed.
no it was a 2nd hand one from Steve (team Lizard) should have fitted sweet as a nut!!
sods law that!!!!
Yep, still think they fitted something upside down.. Ypipe and midpipe do sometimes have a right and a wrong way to fit!
If its Steves why didnt you have it fitted at Abbey? Couldnt they get you in yesterday AM?
should have bloody gone down there, thought it was too far to go!! wish i had of really. i really dont think that the mid pipe can be installed upside down. as the hanger bracket is connected and OK.
UNLESS the Y pipe could be fitted upside down!!!!!!!!!!!!!!!!!!!!! as it looks the same either way up. but there maybe a slight difference!!!!
Ooh never thought of the Y-pipe!
i went back to get this sorted today.
however they are saying that it may have to have the mid pipe spilt then re welded to sort out the rubbing issues. personally i dont think this is the case. i have stuffed some ceramic cloth between the mid pipe and brace. this has sorted it temporally.
i was thinking.... there was 2 holes either side of the mid pipe on the brace. perhaps i could get a U clamp and then bolt it though and hold the mid pipe tight onto the brace!!
would this be OK?
Sparky
