andlid Posted February 18, 2010 Share Posted February 18, 2010 fecking tried to calculate how much oil I needed for gearbox change and thought 3 bottles would be enough, not thinking that US dudes use the 'quarts' system! Now I calcualte that I got 2.835 or somewhere near there and I'd need 2.9 really ... can I go ahead anyway and top up later or will it be enough with 3 quarts? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 18, 2010 Share Posted February 18, 2010 fecking tried to calculate how much oil I needed for gearbox change and thought 3 bottles would be enough, not thinking that US dudes use the 'quarts' system! Now I calcualte that I got 2.835 or somewhere near there and I'd need 2.9 really ... can I go ahead anyway and top up later or will it be enough with 3 quarts? 3 US qt = 3 x 0.94631 = 2.83893 lt. Which is close enough but top up to the required level asap if required. Make sure that the oil is SAE 75W-85 -API GL4+ Alex. Quote Link to comment Share on other sites More sharing options...
andlid Posted February 18, 2010 Author Share Posted February 18, 2010 fecking tried to calculate how much oil I needed for gearbox change and thought 3 bottles would be enough, not thinking that US dudes use the 'quarts' system! Now I calcualte that I got 2.835 or somewhere near there and I'd need 2.9 really ... can I go ahead anyway and top up later or will it be enough with 3 quarts? 3 US qt = 3 x 0.94631 = 2.83893 lt. Which is close enough but top up to the required level asap if required. Make sure that the oil is SAE 75W-85 -API GL4+ Alex. Cheers Alex, already got the fecking wrong oil once (GL5) so got 3 tubs of that sitting there... think I'll just order another bottle from Opie and be done with it... Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 18, 2010 Share Posted February 18, 2010 fecking tried to calculate how much oil I needed for gearbox change and thought 3 bottles would be enough, not thinking that US dudes use the 'quarts' system! Now I calcualte that I got 2.835 or somewhere near there and I'd need 2.9 really ... can I go ahead anyway and top up later or will it be enough with 3 quarts? 3 US qt = 3 x 0.94631 = 2.83893 lt. Which is close enough but top up to the required level asap if required. Make sure that the oil is SAE 75W-85 -API GL4+ Alex. Cheers Alex, already got the fecking wrong oil once (GL5) so got 3 tubs of that sitting there... think I'll just order another bottle from Opie and be done with it... Is Opie not Motul 75W - 90 ????? Quote Link to comment Share on other sites More sharing options...
andlid Posted February 18, 2010 Author Share Posted February 18, 2010 fecking tried to calculate how much oil I needed for gearbox change and thought 3 bottles would be enough, not thinking that US dudes use the 'quarts' system! Now I calcualte that I got 2.835 or somewhere near there and I'd need 2.9 really ... can I go ahead anyway and top up later or will it be enough with 3 quarts? 3 US qt = 3 x 0.94631 = 2.83893 lt. Which is close enough but top up to the required level asap if required. Make sure that the oil is SAE 75W-85 -API GL4+ Alex. Cheers Alex, already got the fecking wrong oil once (GL5) so got 3 tubs of that sitting there... think I'll just order another bottle from Opie and be done with it... Is Opie not Motul 75W - 90 ????? Got redline from them not motul Quote Link to comment Share on other sites More sharing options...
andlid Posted February 19, 2010 Author Share Posted February 19, 2010 was just called a 'f0rum head' by a trader (not internet trader) They don't stock ANY washers for the nissan 350z... in IRELAND 'You're not one of them f0rum heads' ? He thought I knew to much information... and gave out stink too... only in EIRE... I'm off to do this change now. Quote Link to comment Share on other sites More sharing options...
