Husky Posted February 18, 2010 Share Posted February 18, 2010 looking at this almighty spread sheet http://spreadsheets.google.com/ccc?key= ... 5Rnc&hl=en im trying to see if theres anything that would fit the zed i think the PCD is 114.5???? and there aren't any 114.5 in the table. just checking cheers Quote Link to comment Share on other sites More sharing options...
Stew Posted February 18, 2010 Share Posted February 18, 2010 It's 5 x 114 John. Quote Link to comment Share on other sites More sharing options...
Husky Posted February 18, 2010 Author Share Posted February 18, 2010 It's 5 x 114 John. im going nuts then cheers stew no pun intended Quote Link to comment Share on other sites More sharing options...
Jay Posted February 18, 2010 Share Posted February 18, 2010 Yup 5 x 114 What you thinkin of replacing them with mate? Quote Link to comment Share on other sites More sharing options...
Husky Posted February 18, 2010 Author Share Posted February 18, 2010 im hunting around just now bud but im trying not to spend the money on penta's another wheel noob question, i started using search but offset does give you a fair few results you knew this question was coming 19's Quote Link to comment Share on other sites More sharing options...
shire350Z Posted February 18, 2010 Share Posted February 18, 2010 iv never been to clued up on offsets do i take it the lower the number the further out from the hub or......? what offsets are the nismo's? and what should i Zed be using Quote Link to comment Share on other sites More sharing options...
Stew Posted February 18, 2010 Share Posted February 18, 2010 depends on width etc but general consensus is if it's +25 or under it's ok generally. If you want it to look mean though you need to be in the teens. Quote Link to comment Share on other sites More sharing options...
Husky Posted February 18, 2010 Author Share Posted February 18, 2010 would teens bring it further OUT to the arch ? cheers Quote Link to comment Share on other sites More sharing options...
Jay Posted February 18, 2010 Share Posted February 18, 2010 Yes it would husky, would give it a mean looking stance Quote Link to comment Share on other sites More sharing options...
Husky Posted February 18, 2010 Author Share Posted February 18, 2010 cheers Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 18, 2010 Share Posted February 18, 2010 Lower the number the more it sticks out. IMO somewhere around 20-25 is quite conservative, 15-20 is pretty agressive and lower than 15 is mad and mean For reference my Rotas are +25 all round, but I think +20 all round would have been perfect in them Quote Link to comment Share on other sites More sharing options...
shire350Z Posted February 18, 2010 Share Posted February 18, 2010 anyone know what the nismo's are then? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 18, 2010 Share Posted February 18, 2010 anyone know what the nismo's are then? From what I can gather - ~25 on the front and ~20 on the rear EDIT: Or they maybe +30 all round. Found them on Z1auto and there seem to be different specs you can get for the LMGT4s Quote Link to comment Share on other sites More sharing options...
shire350Z Posted February 18, 2010 Share Posted February 18, 2010 so if i was buyng some new rims which were ~28 id need 15mm spacers Quote Link to comment Share on other sites More sharing options...
Husky Posted February 18, 2010 Author Share Posted February 18, 2010 so if i was buyng some new rims which were ~28 id need 15mm spacers if you did i'd be gutted because i just got CS to send a set of 15mm spacers back to eibach i will maybe have some 10mm spacers though Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 18, 2010 Share Posted February 18, 2010 Depends on the width of the wheel too. I'm no expert, but with the offset and spacer you want the overall offset to be about 20ish give or take a few mm and of course depending on your preference. Quote Link to comment Share on other sites More sharing options...
shire350Z Posted February 18, 2010 Share Posted February 18, 2010 so with ~28mm offset a spacer of 15mm would bring it down to ~13 am i right in saying or not? Quote Link to comment Share on other sites More sharing options...
Ian Posted February 18, 2010 Share Posted February 18, 2010 IMO a +12 offset sits about right Have a look at Nrenz car, he has that offset Quote Link to comment Share on other sites More sharing options...
shire350Z Posted February 18, 2010 Share Posted February 18, 2010 IMO a +12 offset sits about right Have a look at Nrenz car, he has that offset get some pictures up what offset does yours sit at ian Quote Link to comment Share on other sites More sharing options...
Ian Posted February 18, 2010 Share Posted February 18, 2010 Mine are +22, I need to find someone local with 10,15,20 & 25mm spacers though so I can test them out & see how far I can go Quote Link to comment Share on other sites More sharing options...
srobrien Posted February 18, 2010 Share Posted February 18, 2010 Mine are +20 rear and +15 front and the offsets looks perfect. Quote Link to comment Share on other sites More sharing options...
rich5259 Posted February 18, 2010 Share Posted February 18, 2010 but what if i go up to 10" wide rims on the rear, do i still need a +15 offset? Quote Link to comment Share on other sites More sharing options...
Ian Posted February 18, 2010 Share Posted February 18, 2010 but what if i go up to 10" wide rims on the rear, do i still need a +15 offset? yes Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 18, 2010 Share Posted February 18, 2010 but what if i go up to 10" wide rims on the rear, do i still need a +15 offset? yes Not sure its as easy as that, but yes, you keep roughly the same offset as wheels get bigger. Tehnically the offset should get larger numbers to compensate I think. Any good wheel vendor should be able to help with it. The main thing is to start of with the width and offset of a wheel you like and work it from there to make the ones you want to match Quote Link to comment Share on other sites More sharing options...
Ian Posted February 18, 2010 Share Posted February 18, 2010 but what if i go up to 10" wide rims on the rear, do i still need a +15 offset? yes Not sure its as easy as that, but yes, you keep roughly the same offset as wheels get bigger. Tehnically the offset should get larger numbers to compensate I think. Any good wheel vendor should be able to help with it. The main thing is to start of with the width and offset of a wheel you like and work it from there to make the ones you want to match Depends if you want wheels that = win or wheels that = fail +12 on a 10.5" wheel is perfect fitment (Awaits Docwra to say that anything above 0 is a failiure ) Quote Link to comment Share on other sites More sharing options...
