magrillz Posted February 15, 2010 Share Posted February 15, 2010 Hi guys, Right, nearly there with my Pioneer F910 install. In fact it is actually in and working fine (I think) however I've noticed somethign weird. The volume seems to be going down very gently and thn back up again. Not literally on the Volume indicator as I've set it to say 15 and it's still on 15 when it seems to go quiet. I can't see any trend to when it happens. Thought it might be some wierd auto volume thing on the Pioneer but can't see any settings. To my limited knowledge this could either be: A - A faulty Bose adapter/signal booster which I have installed that keeps varying the signal strength. B - Maybe during the install we cocked something up wuth the Bose amps. C - Faulty Headunit I had a complete nightmare installing the headunit as the extra Bose adapter took up extra space and the AC unit wouldn't go back in as there are so many cables at the back. So to say I am dreading taking it all out again is an understatement! Has anyone ever seen/heard this wierd behaviour before? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Lexx Posted February 15, 2010 Share Posted February 15, 2010 Does this happen when you speed up/slow down? If so, check the manual as its likely to be an "audio Pilot" or similiarly named function that accounts for the road noise. Quote Link to comment Share on other sites More sharing options...
magrillz Posted February 15, 2010 Author Share Posted February 15, 2010 Hi Lexx, I don't think so, I did notice the volume drop when I switched the engine off though. I'll double check the manual. Cheers mate Quote Link to comment Share on other sites More sharing options...
magrillz Posted February 15, 2010 Author Share Posted February 15, 2010 Found a setting called Dynamic Volume so will try that and see if that makes a difference. The manual implies it's just for Sat Nav but you never know. Will post my findings. Cheers for your help. Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 15, 2010 Share Posted February 15, 2010 I had a Pioneer head unit which did exactly the same thing ...I can't remember the name of the feature now but it changes the volume slighty depending on the level of surrounding noise. I thought I was going mad too .. but then I did something I'd never done before and read the manual ... LoL Ok I've just done some searching and found the name ...it's ASL (Automatic Sound Leveliser) .. See the link below: http://www.pioneer.de/uk/products/25/121/tech/ASL.html Check your manual for this feature or anything similar. Quote Link to comment Share on other sites More sharing options...
magrillz Posted February 16, 2010 Author Share Posted February 16, 2010 Had a look through and searched the .pdf manual for ASL but can't find anything. The nearest thing it has is Dynamic volume which is off. It does have SLA which is to try and match the volume of the Ipod/CD function to the volume of the radio but this is not related. It's wierd I didn't notice it today so going to see how it goes. All very odd, will let you know if I suss it out but thanks for the post. Quote Link to comment Share on other sites More sharing options...
magrillz Posted February 26, 2010 Author Share Posted February 26, 2010 Right then, I think I may have got to the bottom of this. After living with the stereo for a few weeks now and keeping an ear open for the volume change I have ruled out the following: a) The volume is fine when listening to CD’s The volume is fine when listening to the IPOD. c) The volume only goes up and down when listening to the radio So rather embarrassed to report it seem that the radio signal strength is dropping and instead of getting the usual choppy signal it seems to go a bit quiet instead. Feel like a bit of a doughnut but at least I know it’s not faulty. Never had a problem with the factory unit’s reception but may just be one of those things. Quote Link to comment Share on other sites More sharing options...
