will350 Posted February 12, 2010 Share Posted February 12, 2010 hey can anyone help me out i recently got an engine code checked which came up as P0350 i found that it was one of the coil packs which needs changing but how do i find out which 1 as the computer couldnt pick out which 1 was faulty. There are 6 to choose from and i can't get nissan UK to look at it for a month at least (TWATS) anyone got any suggestions as to what i should do and where i can get the part from as i am struggling to find 1 at short notice. The car is missfiring and juddering when i drive it but i cant not drive it as i need to get to work in it cheers will Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 12, 2010 Share Posted February 12, 2010 download the service manual in the Guides subforum not sure if its advisable to change just one or if its best to change all six. Someone else will be along to advise Quote Link to comment Share on other sites More sharing options...
dcash5 Posted February 12, 2010 Share Posted February 12, 2010 Held in with 1 10 mm bolt. Read the guides on the spark plug removal and that'll tell you, not a hard job but a bit fiddly moving cables about. You dont need to remove the plenum as Nissan would advise Quote Link to comment Share on other sites More sharing options...
will350 Posted February 12, 2010 Author Share Posted February 12, 2010 yea but how am i supposed to know which coil pack is the faulty one and any ideas on where i can get the new part cheaply nissan offered it £69 but didnt have it in stock Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 12, 2010 Share Posted February 12, 2010 you could pm ZMANALEX or R35LEE to see if they have any used ones available. ZMANALEX may even be able to get it new cheaper than Nissan Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 12, 2010 Share Posted February 12, 2010 I have plenty preowned coil packs available @ £20.00 each. If you can not identify which one is giving you the grief, then you will just have to swop out one at a time followed by a short road test until the issue is resolved. PM me if you would like one sent over. Alex. Quote Link to comment Share on other sites More sharing options...
Steady Zeddy Posted February 13, 2010 Share Posted February 13, 2010 AFAIK - the engine check light for the coil packs will give you the number coilpack that is having the issue? Its not a difficult job to change on the Zed in any case. Quote Link to comment Share on other sites More sharing options...
trackpig Posted February 18, 2011 Share Posted February 18, 2011 I have plenty preowned coil packs available @ £20.00 each. PM me if you would like one sent over. Alex. Hi Alex Do you have any pre owned coil packs in stock? I could also do with an injector. Are the injectors hard to change? I only want them as spares for a nurburging/ spa trip. Cheers Kevin. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 18, 2011 Share Posted February 18, 2011 Plenty preowned injectors and coil packs in stock mate. Both very easy to swop out. Alex Quote Link to comment Share on other sites More sharing options...
trackpig Posted February 18, 2011 Share Posted February 18, 2011 I meant to send that on a PM. Quote Link to comment Share on other sites More sharing options...
Blacky Posted February 18, 2011 Share Posted February 18, 2011 yea but how am i supposed to know which coil pack is the faulty one and any ideas on where i can get the new part cheaply nissan offered it £69 but didnt have it in stock If you have a continous misfire, you could remove the electrical plug on each coilpack one at a time. The one that doesnt make any difference to engine running is the one you need to change. If you want to make doubly sure swap it with one of the others an if the misfire moved, bobs your mothers uncle in law. Quote Link to comment Share on other sites More sharing options...
