Does it really matter Servicing at Nissan??
jerry3167
If its brand new out the box, it should be pre oiled Jerry :thumbs: (maybe worth checking with your supplier). Dont be supprised when Mark tells you to make better gains you have to use the OEM airbox :lol:
:surrender: So, should I put a stock airbox on for the run?
depends on what you want.
jwt = more noise, a small performance drop
stock airbox with performance filter element = a couple more bhp but less induction noise.
i will post up my results as soon as i'm done, and i'm sure jerry would do the same
Yep, I go to Mark @ Abbey with the following:
MD Plenum spacer 5/16ths
High Flow Cats
JWT Pop Charger.
5 ZIGEN Pro-Racer Cat Back
Thanks guys. When are you both getting your remaps done?
Yeah I was just messing, the drop in HP is tiny. I think on Andys car it was like 2HP or something top end. TBH I'm not conviced that on the road it makes any difference at all as I have seen very similar IATs with the popcharger and stock airbox. On the dyno though, the popcharger definately gets heatsoaked a bit. Sure Mark will keep an eye on IATs :thumbs:
