Changing power steering fluid!!
GT4 Zed
Anyone please tell me how to change the power steering fluid. I can't seem to find a drainage or bleed point while underneath the zed most of today sorting my A camber arms and adjusting the suspension :surrender:
There is no DIY guide in the service manual or 350 z tech wiki and i wouldn't want to create and air lock by going at it gong-hoo stylee!! :teeth:
cheers
I've just changed my cooler as it was leaking, I'm sure if you just disconnect the bottom hose on the cooler it will all drain out, as for air locks, once you filled it up, start the car without the lid on and keep turning wheels to full lock each way a few times, that should get rid of any air in the system
