Kinetix V4 plenum: issues! Kinetix CS sorts it!
Removed
Kinetix sent me a replacement after showing them pictures of the defect my old V4 had developed, the new V+ seems to be a much better product!
:scare:
after a few months with no issues at all... the below happens.
I'm quite scared of driving the car tbh! rang and emailed Kinetix just now... should I put the standard back on??? Problem is I have no time! earliest will be Thursday... damn!
Hopefully they'll back up their lifetime product warranty... doesn't seem too bad, car drives ok... but surely I don't want it to get any worse and it's coming off...spent lots of money and time colourcoding it too, they'll have to sort that :dry:
Cant see them refunding you for your cans of halfords paint, but they will sort you out with a new plenum.
those "cans of Halfords paint" costed me over £70 all in .... mate :dry: in fact probably more (at least 5 cans of colour £10 each, same with primer and at least 3 laquer). PLUS labour
and yes I'll make sure they make it up to me. Oh and no more plastic plenums for me I'm afraid...
If that was a Nissan item they would definately blame the paint to get out of any warranty claims...:lol:
Whats the betting Kinetex do to :blush:
AFAIK they are a serious Company who honour their peoducts' warranties :) that was one of the reasons I chose them in the first place. Will elt you know
PS Tim, go on I wanna hear how they'd justify it if they sd the paint was to blame for the plenum melting :lol:
dont want to upset you Val :blush: BUT.., quite often paint will react with various plastics and alter their composition... dont ask me how!! I only got to "O" level in Chemistry... I've seen guys spray cheap motorcycle helmets and end up with a lump of snot on their head :scare:
considering this is not a cheap item and supposed to withstand temperatures within the engine bay... not very plausible imo.
Also, surely if it was to react to the paint, it would have done straight away, not after months ;) it's simply their product that has failed, the painted surface is actually intact.
As I said, there's already a precedent for this type of failure (well at least one known in the US) and that wasn't even painted.
Well I hope your right Val... and they send you out a replacement quickly :thumbs: will they want the old one sending back or just photos of the faulty one?
don't know as I just contacted them today mate. Still, I'm not paying anything, that's for sure.
Your quite correct , there shouldnt be an issue with this., they should be designed to withstand heat and paint applications..After all it is subjected to oil spillage , coolants , petrol etc..
:scare:
I know I'm stupid and have a yellow car (blah blah) but what has actually happened? Can't see from the pics what I'm supposed to be looking at? :blush:
:scare:
Its starting to flex/melt :surrender:
Unless you are sure of exactly what plastics its made of, and what is in the paint/how they react, how can you be sure that the paint hasnt changed the properties of the plastic plenum?? All guess work.
well then if it was the paint's fault (i can't believe you lot are actually suggesting this :lol: ) there should be some thousands owners in the US with the same issue, having colour coded the plenum, since the very first versions that came out. And as i said before, any reaction would have showed straight after or soon after colourcoding it/fitting it. it's been on for months. I bet the hotter than normal weather is to blame (causing higher than normal engine bay temperatures) to be honest. Still, this should not have happened.
Kinetix haven't got in contact yet. Rang them about 5 times yesterday (California times, exactly the times they state they are open) left message, sent email. Let's see how good their Customer Service is.
Actually I would also think that they may use the paint as a reason to void any product warranty.
It may not be that the paint has reacted with the plastic, but it will certainly have acted as an insulator to the plastic. I assume they may say that the plastic will not have been able to dissipate the heat as effectivley with the coating of paint.
Just the same as a radiator thick with paint will not dissipate the heat as effectively as one in bare copper.
HOWEVER....
The paint would hardly have insulated the plastic to the degree where it alone could be blamed for heat building up to that extent - if it has, Ill spray my loft with it.
And I am quite honestlyshocked that they have constructed a plastic part for an engnine bay that is not thermosetting (heat hardens rather than softens).
This is a fire hazzard waiting to happen imho, I'd put the standard one back on ASAP until this is sorted out.
plastic doesn't conduct heat afaik... certaintly doesn't conduct as much as aluminium, that's for sure. The type of plastic they used is supposed to withstand engine bay heat, that's the whole point... otherwise how could they market this type of product?
Since there's been other cases of this type of failure, this is a classic case of their product failing. The pics of another product doing exactly what mine has done, were of a non painted product, further strenghtening my case. Also, as they have been posting on my350z since the beginning, and saw a large amount of their plenums being painted, if they had received a lot of complaints due to them melting (which they haven't, it's a rare issue) they should have started putting warnings in their instruction packs NOT TO PAINT. Which they haven't. And mine is a recent version of the plenum, just 1 version behind the latest.
To be honest, their product on paper is the perfect plenum: retains the oem strut bar, retains the engine cover, saves on quite a lot of weight, adds HP etc. And up to now I was very happy with the product.
