Demolition49 Posted February 3, 2010 Share Posted February 3, 2010 I'm looking at replacing the Bose stereo in the 350z with an alpine head unit (Alpine IVA-W505R) Im wondering what im going to need to make it flush, will i need an adapter? Any of you guys sell them? Secondly ive got the following AMP and Subwoofer from my old car, will they fit.... Orion HCCA-D5000 (Amplifier) Orion HCCA Subwoofer (12.2") 4000 watt. Will they fit? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 3, 2010 Share Posted February 3, 2010 moved check out the FAQ's A post there by rob_quads should answer most q's. Its also the first sticky in this subforum Quote Link to comment Share on other sites More sharing options...
helimeddaz Posted February 3, 2010 Share Posted February 3, 2010 Hi, Thought this might help... viewtopic.php?f=27&t=28015 Quote Link to comment Share on other sites More sharing options...
Demolition49 Posted February 3, 2010 Author Share Posted February 3, 2010 Ive just had some second thoughts! Will steering controls work if the bose is replaced with the alpine?!?! If it doesnt which aftermarket will? If any!? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 4, 2010 Share Posted February 4, 2010 did you read the FAQ Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted February 4, 2010 Share Posted February 4, 2010 did you read the FAQ Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 4, 2010 Share Posted February 4, 2010 did you read the FAQ thought you'd like that rob Quote Link to comment Share on other sites More sharing options...
helimeddaz Posted February 4, 2010 Share Posted February 4, 2010 Ive just had some second thoughts! Will steering controls work if the bose is replaced with the alpine?!?! If it doesnt which aftermarket will? If any!? Lots of companies make a module, so all the steering controls work. no problem... Quote Link to comment Share on other sites More sharing options...
Danny 350Z Posted February 4, 2010 Share Posted February 4, 2010 Ive just had some second thoughts! Will steering controls work if the bose is replaced with the alpine?!?! If it doesnt which aftermarket will? If any!? Lots of companies make a module, so all the steering controls work. no problem... http://www.incartec.co.uk/ Quote Link to comment Share on other sites More sharing options...
Demolition49 Posted February 8, 2010 Author Share Posted February 8, 2010 Thanks for all the help everybody, I have had a read through the FAQ's and from what i can gather i will need the following items: ICT 50-306 - Nissan 350Z 06 Onwards - Single DIN & Pocket OR Double DIN http://www.sextonsdirect.co.uk/facia_pa ... 0-306.html ICT 29-674 - Nissan 350z Bose USC Loom http://www.sextonsdirect.co.uk/facia_pa ... html?cat=0 ICT 29-007 (Pioneer head-unit lead) http://www.sextonsdirect.co.uk/steering ... html?cat=0 What my intentions are to take out the Bose head unit, replace with the alpine W505R. I assume i have all the wiring i need for that above. I would also eventually like to take out the Bose amp and power the speakers with my own amp and then i will have another amp for my sub-woofer, would that be ok or do i need more looms etc? Im not actually going to be doing the install but i want to have all the parts etc for when i do get this all done. Cheers guys. You been alot of help. Quote Link to comment Share on other sites More sharing options...
confuzed Posted February 8, 2010 Share Posted February 8, 2010 ICT 29-007 (Pioneer head-unit lead) http://www.sextonsdirect.co.uk/steering ... html?cat=0 What my intentions are to take out the Bose head unit, replace with the alpine W505R. If you're fitting an alpine head unit, don't you need the alpine remote cable for the steering wheel control unit? http://www.sextonsdirect.co.uk/fitting_ ... ml?cat=659 Quote Link to comment Share on other sites More sharing options...
Demolition49 Posted February 8, 2010 Author Share Posted February 8, 2010 ICT 29-007 (Pioneer head-unit lead) http://www.sextonsdirect.co.uk/steering ... html?cat=0 What my intentions are to take out the Bose head unit, replace with the alpine W505R. If you're fitting an alpine head unit, don't you need the alpine remote cable for the steering wheel control unit? http://www.sextonsdirect.co.uk/fitting_ ... ml?cat=659 Changed my mind mate, i decided to go for the pioneer as it has reversing camera, much needed for the 350z IMHO! So apart from that, am i set to go? Quote Link to comment Share on other sites More sharing options...
confuzed Posted February 8, 2010 Share Posted February 8, 2010 So apart from that, am i set go? For a straight head unit swap, yeah it looks like you're good to go Quote Link to comment Share on other sites More sharing options...
Demolition49 Posted February 8, 2010 Author Share Posted February 8, 2010 So apart from that, am i set to go? For a straight head unit swap, yeah it looks like you're good to go Thanks dude, what about my sub and amp? Are there some issues with removing that Bose amp? Quote Link to comment Share on other sites More sharing options...
confuzed Posted February 10, 2010 Share Posted February 10, 2010 Thanks dude, what about my sub and amp? Are there some issues with removing that Bose amp? I'm afraid I can't be of help with that, I've only swapped the HU which I run through the Bose amp and speakers. There are quite a few threads on here that discuss your options. Quote Link to comment Share on other sites More sharing options...
yokomo Posted February 10, 2010 Share Posted February 10, 2010 bose "sub" and its "amp" are just un plugged takes about 2 minutes ! as for removing the main bose amp that runs the mids/tweeters im not sure ... couldnt get the darn packing thing out the boot(well i dint want to pull that hard incase i broke it) but its under the near side of the boot. if you do got for a proper amp to run your setup you could just leave it there since the headunits outputs will be reconnected to your amp. Quote Link to comment Share on other sites More sharing options...
magrillz Posted February 11, 2010 Share Posted February 11, 2010 Thanks for all the help everybody, I have had a read through the FAQ's and from what i can gather i will need the following items: ICT 50-306 - Nissan 350Z 06 Onwards - Single DIN & Pocket OR Double DIN http://www.sextonsdirect.co.uk/facia_pa ... 0-306.html ICT 29-674 - Nissan 350z Bose USC Loom http://www.sextonsdirect.co.uk/facia_pa ... html?cat=0 ICT 29-007 (Pioneer head-unit lead) http://www.sextonsdirect.co.uk/steering ... html?cat=0 What my intentions are to take out the Bose head unit, replace with the alpine W505R. I assume i have all the wiring i need for that above. I would also eventually like to take out the Bose amp and power the speakers with my own amp and then i will have another amp for my sub-woofer, would that be ok or do i need more looms etc? Im not actually going to be doing the install but i want to have all the parts etc for when i do get this all done. Cheers guys. You been alot of help. I think for the Pioneer headunit it is now advised to go for the 29-020. Works on my F910 anyway. If you are not sure on your particular headunit try ringing InCarTec on 01392829435 Quote Link to comment Share on other sites More sharing options...
