rtbiscuit Posted February 1, 2010 Share Posted February 1, 2010 i'm due to fit my new plenum and throttle body spacer soon and do all at the same time etc. what i need to know is the bolt dimensions of the current 4 bolts used to hold the throttle body onto the plenum. i need to find 4 new ones that are about an inch longer to allow for the spacer. or if someone can supply me with some would be even better Quote Link to comment Share on other sites More sharing options...
andlid Posted February 1, 2010 Share Posted February 1, 2010 i'm due to fit my new plenum and throttle body spacer soon and do all at the same time etc. what i need to know is the bolt dimensions of the current 4 bolts used to hold the throttle body onto the plenum. i need to find 4 new ones that are about an inch longer to allow for the spacer. or if someone can supply me with some would be even better No answer on the other thread I take it, if you can wait until tomorrow I can go out and take one of them out and give you a measure, Id bring it to a engineering place and just hand them the bolt and ask them if they do it in xxx mm, worked the last time I needed a bolt (amazing). Go past there from time to time so if you want me to pick you up 4 I could and post them. Possibly cheaper to sort out yourself Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 i'm due to fit my new plenum and throttle body spacer soon and do all at the same time etc. what i need to know is the bolt dimensions of the current 4 bolts used to hold the throttle body onto the plenum. i need to find 4 new ones that are about an inch longer to allow for the spacer. or if someone can supply me with some would be even better No answer on the other thread I take it, if you can wait until tomorrow I can go out and take one of them out and give you a measure, Id bring it to a engineering place and just hand them the bolt and ask them if they do it in xxx mm, worked the last time I needed a bolt (amazing). Go past there from time to time so if you want me to pick you up 4 I could and post them. Possibly cheaper to sort out yourself yeah nothing on the other thread, got the impression no one was reading it. might be a plan, am happy to pay for them, haven't got anyone near me to take it to. and need the bolt in the engine so i can drive there also out of interest, how far do the bolts go into the plenum? i suppose if they are too long i can cut them down Quote Link to comment Share on other sites More sharing options...
Ian Posted February 1, 2010 Share Posted February 1, 2010 Doesn't the spacer come with extended bolts? where did you get it from? Why are you fitting it? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 Doesn't the spacer come with extended bolts? where did you get it from? Why are you fitting it? got it from zmanalex, no bolts with it, just the spacer, fitting it because it looks nice Quote Link to comment Share on other sites More sharing options...
Ian Posted February 1, 2010 Share Posted February 1, 2010 Gay When are you fitting it? I've got one on order from Adam that I am sure comes with bolts, If you can wait a couple of weeks I can tell you the size of them then? or you could drop Adam a pm and ask him the size Quote Link to comment Share on other sites More sharing options...
andlid Posted February 1, 2010 Share Posted February 1, 2010 i'm due to fit my new plenum and throttle body spacer soon and do all at the same time etc. what i need to know is the bolt dimensions of the current 4 bolts used to hold the throttle body onto the plenum. i need to find 4 new ones that are about an inch longer to allow for the spacer. or if someone can supply me with some would be even better No answer on the other thread I take it, if you can wait until tomorrow I can go out and take one of them out and give you a measure, Id bring it to a engineering place and just hand them the bolt and ask them if they do it in xxx mm, worked the last time I needed a bolt (amazing). Go past there from time to time so if you want me to pick you up 4 I could and post them. Possibly cheaper to sort out yourself yeah nothing on the other thread, got the impression no one was reading it. might be a plan, am happy to pay for them, haven't got anyone near me to take it to. and need the bolt in the engine so i can drive there also out of interest, how far do the bolts go into the plenum? i suppose if they are too long i can cut them down Cool, Ill have a look tomorrow. A Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 Gay When are you fitting it? I've got one on order from Adam that I am sure comes with bolts, If you can wait a couple of weeks I can tell you the size of them then? or you could drop Adam a pm and ask him the size am waiting on my carbon plenum before fitting and then going for a remap at abbey, i'm aiming for about 2 weeks time for the remap as it will be half term (haven't checked with abbey yet ) i'll try adam see if he can send me some Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 1, 2010 Share Posted February 1, 2010 The oem ones are 60mm x 5mm Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted February 1, 2010 Share Posted February 1, 2010 If it wasnt so cold I would go to the garage and measure the ones that came off the TB spacer I took off on Saturday... but it is cold and I cant be arsed! Guessing though if you take the size of the bolts that alex just added and then add the thickness of the spacer your pretty much there!! But you thought of that didnt you!!! You just need the pitch and diameter now! Will look tomorrow if you dont get the answers tonight! Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 The oem ones are 60mm x 5mm the spacer is exactly 22 mm thick so i guess i'll need something like a 80mmx5mm bolt. i am right in thinking these are an alan key head Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 If it wasnt so cold I would go to the garage and measure the ones that came off the TB spacer I took off on Saturday... but it is cold and I cant be arsed! Guessing though if you take the size of the bolts that alex just added and then add the thickness of the spacer your pretty much there!! But you thought of that didnt you!!! You just need the pitch and diameter now! Will look tomorrow if you dont get the answers tonight! cheers mark, was just outside getting the spacer to measure pitch and diameter would be great Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 1, 2010 Share Posted February 1, 2010 The oem ones are 60mm x 5mm the spacer is exactly 22 mm thick so i guess i'll need something like a 80mmx5mm bolt. i am right in thinking these are an alan key head Correct and metric fine I think. Quote Link to comment Share on other sites More sharing options...
andlid Posted February 1, 2010 Share Posted February 1, 2010 Saves me checking tomorrow so Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 Saves me checking tomorrow so cheers for the offer of help, once i have the thread pitch, i'll get online and order some Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 just to clarify that length of 60mm is that just the thread or is that including the hex head? i'm guessing its just the thread, having fun trying to source M5x80mm socket head cap screws, so far the places only go up to 60mm or the one i've found jumps to 90. not a major problem as i can cut it down and re tap it. Quote Link to comment Share on other sites More sharing options...
srobrien Posted February 1, 2010 Share Posted February 1, 2010 Saves me checking tomorrow so cheers for the offer of help, once i have the thread pitch, i'll get online and order some I would imagine they would be 1.00 pitch same as the other plenum bolts. Edit: Actually its more likely to be 0.8 if they are M5 http://cgi.ebay.co.uk/M5-x-80-Stainless ... 563257117c R Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 i would say 0.8 as well, but i'll wait for mark to clarify tomorrow Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 found some but they only sell them in sets of 200 or i can get them individually, but they are 10mm to long and the head isn't as good as the others anyone know of a good supplier? do you reckon the chillis' do them in anodised red? Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted February 1, 2010 Share Posted February 1, 2010 found some but they only sell them in sets of 200 or i can get them individually, but they are 10mm to long and the head isn't as good as the others anyone know of a good supplier? do you reckon the chillis' do them in anodised red? Yep probably! But black or chrome would be better! You not got a fixings store near you? Got one just down the road and they have loads of stuff... as mine is off the car I can take one down and see what they have... Wont be till the weekend though Quote Link to comment Share on other sites More sharing options...
srobrien Posted February 1, 2010 Share Posted February 1, 2010 Saves me checking tomorrow so cheers for the offer of help, once i have the thread pitch, i'll get online and order some I would imagine they would be 1.00 pitch same as the other plenum bolts. Edit: Actually its more likely to be 0.8 if they are M5 http://cgi.ebay.co.uk/M5-x-80-Stainless ... 563257117c R *Cough* Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 thanks ross, saw them, just wondered if they have to be threaded the whole length or not? not dismantled the throttle body yet so a bit unsure Quote Link to comment Share on other sites More sharing options...
srobrien Posted February 1, 2010 Share Posted February 1, 2010 Wouldn't have thought so as they only secure into the plenum. R Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 found some but they only sell them in sets of 200 or i can get them individually, but they are 10mm to long and the head isn't as good as the others anyone know of a good supplier? do you reckon the chillis' do them in anodised red? Yep probably! But black or chrome would be better! You not got a fixings store near you? Got one just down the road and they have loads of stuff... as mine is off the car I can take one down and see what they have... Wont be till the weekend though there isn't one near me that i'm aware of, plus i like ordering over the net, so i don't have to go into town Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 1, 2010 Author Share Posted February 1, 2010 Wouldn't have thought so as they only secure into the plenum. R might just get them then Quote Link to comment Share on other sites More sharing options...
