nrenz123 Posted January 29, 2010 Share Posted January 29, 2010 Hi guys during the last two weeks while starting the car fror cold after it has been sat for a day or two, on two occasions i have had a misfire on starting the engine. It misfires then dies down to idle and is fine but if u rev the engine it will misfire for a perioid of about 5 seconds then the problem goes away. It doesnt do it at any other time apart from a cold start (in cold weather) is trhere anything i should check? plugs were changed about 3k ago. Injectors? Coil pack? Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 29, 2010 Share Posted January 29, 2010 Mods? Quote Link to comment Share on other sites More sharing options...
nrenz123 Posted January 29, 2010 Author Share Posted January 29, 2010 At the moment Just a pop charger engine wise. The plenum was removed about 5 months ago also just for info. Also the exhaust has snapped at the weld from the mid pipe to the back box. i'm waiting for japspeed to get the k2's in stock the back box and mid pipe align fine there is just a little gap between them sounds good though! lol. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 29, 2010 Share Posted January 29, 2010 At the moment Just a pop charger engine wise. The plenum was removed about 5 months ago also just for info. Also the exhaust has snapped at the weld from the mid pipe to the back box. i'm waiting for japspeed to get the k2's in stock the back box and mid pipe align fine there is just a little gap between them sounds good though! lol. Wont be your zorst. Could be an ecu reset to start with, check all your vacuum hoses esp if the plenum has been messed with, esp the one under the z-tube. If not then it could be your coilpacks, you checked since the sparks were sorted? Quote Link to comment Share on other sites More sharing options...
nrenz123 Posted January 29, 2010 Author Share Posted January 29, 2010 What the dickens is the z tube? im guessing a hose in the shape of a z? i'll check all the hoses and go from there an esu reset being next. im going back to wales tomorrow so ill take it to the place where it was serviced. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 29, 2010 Share Posted January 29, 2010 What the dickens is the z tube? im guessing a hose in the shape of a z? i'll check all the hoses and go from there an esu reset being next. im going back to wales tomorrow so ill take it to the place where it was serviced. Z-tube is the tube that connects your pop to your plenum! or thats what the oem one is called anyway! There is a vacuum hose connected underneath Quote Link to comment Share on other sites More sharing options...
nrenz123 Posted January 29, 2010 Author Share Posted January 29, 2010 Ah right ok, i'll do a check of them aswell. its strange it doesnt do it every time i just have visions of pistons and rings as thats what happened on my previous car. although that was a fiat coupe! Quote Link to comment Share on other sites More sharing options...
