V88 REG Posted January 29, 2010 Share Posted January 29, 2010 Is there a guide to removing the trim behind the seats. I.E glove boxes, boot trim ? Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 29, 2010 Share Posted January 29, 2010 search google for morpheous 350z Quote Link to comment Share on other sites More sharing options...
V88 REG Posted January 29, 2010 Author Share Posted January 29, 2010 tried it but it only shows around the centre console tho Quote Link to comment Share on other sites More sharing options...
Andy Posted January 29, 2010 Share Posted January 29, 2010 The whole lot is push clips. You have to start with the long thin trim piece that runs over the lower rubber strip by the door. After that the piece higher up the B pillar comes off....the piece that goes round the seatbelt bracket point and goes into the first section of the boot. Repeat the other side. The small gloveboxes are removed by opening them then pulling them out...GENTLY, the doors can snap off easily! Once these are out, the section that covers the rear speakers will come off, again with just push clips iirc. Once that is off you can take the panel off that the gloveboxes are on but remember not to pull it too far from the metal work as the 12v output connection needs to be undone before you can fully remove it. This is all from my memory of a few years ago when I first took all mine out and as I have changed a few bits since then it may not be 100% but it is how I remember it to be Quote Link to comment Share on other sites More sharing options...
V88 REG Posted January 29, 2010 Author Share Posted January 29, 2010 i just had another look for it and found it so il give it a go. Doesnt look hard just have to be careful not to break the clips. Just needed to know where to start really rather than start pulling trim in random order Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 29, 2010 Share Posted January 29, 2010 tried it but it only shows around the centre console tho You didnt hit the back button in the top left of the screen http://liljerk.morpheus.net/350Z/ Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 29, 2010 Share Posted January 29, 2010 As Andy says, start at the bits by the seat and work backwards. You cant do it in the wrong order as they all overlap, so if you find a panel you cant remove, find the one that overlaps it and take that off Go easy and use a trim removal tool, its all dead easy to do when you get going Quote Link to comment Share on other sites More sharing options...
pathfinder123 Posted January 29, 2010 Share Posted January 29, 2010 As Andy says, start at the bits by the seat and work backwards. You cant do it in the wrong order as they all overlap, so if you find a panel you cant remove, find the one that overlaps it and take that off Go easy and use a trim removal tool, its all dead easy to do when you get going "trim removal tool"... Is this different to a screwdriver ? Maybe something for me to buy... S. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 29, 2010 Share Posted January 29, 2010 Like a screw driver with a split end so it can go around the pins and push directly on their mounts rather than the surrounding softer plastic http://www.caraudiodirect.co.uk/second- ... opper.html Quote Link to comment Share on other sites More sharing options...
Andy Posted January 29, 2010 Share Posted January 29, 2010 +1 very useful tool indeed Quote Link to comment Share on other sites More sharing options...
V88 REG Posted January 29, 2010 Author Share Posted January 29, 2010 i bought one of them and th roller came this morning. ordered at 4 yesterday im dunna sound proff ma ass off!! Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted January 29, 2010 Share Posted January 29, 2010 "trim removal tool"... Is this different to a screwdriver ? Maybe something for me to buy... S. Jeremy Clarkson believes that this is a ball pein hammer Quote Link to comment Share on other sites More sharing options...
MrLizard Posted January 29, 2010 Share Posted January 29, 2010 flat head screw driver and a cloth worked for me Quote Link to comment Share on other sites More sharing options...
pathfinder123 Posted January 29, 2010 Share Posted January 29, 2010 Like a screw driver with a split end so it can go around the pins and push directly on their mounts rather than the surrounding softer plastic http://www.caraudiodirect.co.uk/second- ... opper.html Thanks - now 'er Indoors knows what to buy me for my Birthday... S. Quote Link to comment Share on other sites More sharing options...
