Tricky-Ricky Posted January 28, 2010 Share Posted January 28, 2010 Just wondering if the brake and clutch peddles adjustable? i like smaller movement (within reason) i found my old S14 was adjustable, so hoping the 350 will be too. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted January 28, 2010 Share Posted January 28, 2010 i know the height on the brake can be adjusted, as i plan to do it soon when i get my new accelerator pedal, i find the OEM setup is very hard to heel and toe in. the brake pedal is too high and the throttle is just a bit too far over. new pedal and lowering the brake should fix this. there should be a guide, Chris did it and said its fiddly. not sure how adjustable it is, on the lines of what your looking for though? as for clutch, don't know, Quote Link to comment Share on other sites More sharing options...
lrh Posted January 29, 2010 Share Posted January 29, 2010 My clutch pedal sat high with loads of slack that made smooth gear changes hard. You'll need to move the ECU out of the way but even using a mirror it was a fiddle to lower the pedal without applying any pressure to the rod. Well worth the effort though. This is a picture of a what's hidden under the dash. The bolt in the top left adjusts the height. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 29, 2010 Author Share Posted January 29, 2010 Thanks looks pretty similar to the S14 setup. Quote Link to comment Share on other sites More sharing options...
