jim Posted January 23, 2010 Share Posted January 23, 2010 My battery is starting to play up after not being used for most of the recent cold spell. In fact, it's on the charger at the moment after failing to start the car this morning. Although the car started after only a few minutes on the charger, I think this is the first sign that the battery may be needing replaced soon. Having searched a few threads, I know that a few people have had to make the same change recently. However, apart from one member who got a Vartia battery at ABS in Guildford, I can't seem to find out what people eventually found to replace theirs. Can anyone who has replaced their battery recommend a specific model that is close to the spec of the original JDM one? Quote Link to comment Share on other sites More sharing options...
CarlosCh Posted January 23, 2010 Share Posted January 23, 2010 Most people simply replace the OEM battery for an Optima Yellow Top D35... which holds great charge and supports quite a bit of abuse in the form of many electronics working even if the car has not been started. I took a different route at some point in the past -but keep in mind this is not a deep cycle battery and *will* die if you use it to anything other to start the car: Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted January 23, 2010 Share Posted January 23, 2010 I used to have a Stinger Sp1000 on my FTO so it would run all my ice too,it was pretty costly at £300 though,then i had to get terminals & cut of the cars original ones.ended up spending an extra £60+ on some platinum autoleads terminals with a digital display on the +tive terminal Quote Link to comment Share on other sites More sharing options...
jim Posted January 23, 2010 Author Share Posted January 23, 2010 I'm not using anything much in terms of ICE or Satnav, so I just need a standard battery. Halfords seem to have a reasonable range - I'll surely get one to fit the space OK. Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted January 23, 2010 Share Posted January 23, 2010 Yeah id of thought so matey,the battery is bound to fit another nissan surely.Or another car for that matter.The standard FTO battery on my first one was the one for a micra from halfrauds Quote Link to comment Share on other sites More sharing options...
choptop Posted January 23, 2010 Share Posted January 23, 2010 Take the old battery out and go to your nearest Partco. They will sort you out a battery that will fit for around £30 Quote Link to comment Share on other sites More sharing options...
