MattMe Posted January 22, 2010 Share Posted January 22, 2010 Hi. I recently got some Falken 912s fitted when my Bridgestones finally wore out. I noticed that the centres of the tyres were considerably more worn than the outer edges. I know I used to run 36psi after reading some advice on here - now I'm starting the think that might be a bit high! When they changed the tyres I said to put 34 in all 4 but then last night when walking to the car park I noticed the dirt on my tyres wa still only on the middle of the tread, not the outer edges. So I'm thinking 34 may be too high too. In the past on all my other cars I've only ever put in 28-30 and had no problems. Does weight etc of the car effect what pressue you should put in the tyres? My logic tells me that every tyre, whatever the size should be about the same psi, but I could be tottaly wrong. Does it vary from tyre to tyre even? I don't know! I do know I'm going to try running about 30 psi and see what it feels like... What does everyone else run here - tyre make/psi? Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted January 22, 2010 Share Posted January 22, 2010 Something similar posted recently viewtopic.php?f=61&t=31497 Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted January 22, 2010 Share Posted January 22, 2010 should be 35 psi sounds like you need to get your tracking checked and a wheel alignment done Quote Link to comment Share on other sites More sharing options...
