introspect Posted January 22, 2010 Share Posted January 22, 2010 After the cold weather I seem to suddenly have an annoying squealing sound from my auxiliary belts. Can't actually hear it from within the car, except with widows down. Is this something that is likely to be covered under warranty or is it classed as a consumable item? Quote Link to comment Share on other sites More sharing options...
350zjimbo Posted January 22, 2010 Share Posted January 22, 2010 I'd be very surprised if you could get that covered under Waranty. Funny though as I have exactly the same problem with mine after the weather. Quote Link to comment Share on other sites More sharing options...
cookiemonster Posted January 22, 2010 Share Posted January 22, 2010 Maybe time for a change? Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted January 22, 2010 Share Posted January 22, 2010 a lot of people have complained of this after the cold weather. I'd play it safe and get them replaced anyway, cheap and easy DIY job anyhow Quote Link to comment Share on other sites More sharing options...
introspect Posted January 22, 2010 Author Share Posted January 22, 2010 a lot of people have complained of this after the cold weather. I'd play it safe and get them replaced anyway, cheap and easy DIY job anyhow Yes you're probably right, I was just trying to be a cheapskate Quote Link to comment Share on other sites More sharing options...
Vik54 Posted January 22, 2010 Share Posted January 22, 2010 yup - similar issues here - I've prolly got these going on at the weekend http://www.350z-uk.com/forum/viewtopic.php?f=38&t=31548 and .........no I'm not on commission Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted January 22, 2010 Share Posted January 22, 2010 I had my belts replaced just before the cold snap. As it started to get colder my belts started to squeal. It ended up they were a bit too loose and the cold weather meant it resulted squealing. What does this mean. If your belts are old its because they are probably stretched and a bit loose. You can either tighten them up a bit (but this may break them) or replace them. If your belts are in good condition just a little tighten up will probably sort them. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 22, 2010 Share Posted January 22, 2010 classed as a consumable item? it is Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted January 22, 2010 Share Posted January 22, 2010 perfect timing for you - viewtopic.php?f=38&t=31548 Quote Link to comment Share on other sites More sharing options...
P19DRO Posted January 22, 2010 Share Posted January 22, 2010 I had my belts replaced and it would still squeal till the engine warmed up, turned out the nut on the pulley for the main belt was far to tight. Destroyed the nut getting it off as well Quote Link to comment Share on other sites More sharing options...
