ug45cwb Posted January 22, 2010 Posted January 22, 2010 Noticed today the sound recorder app plays back crystal clear through the bluetooth module when the phone is paired. Unfortunately the only sounds you can play are ones you have recorded yourself. Surely it would not be that difficult to develop an app that can play MP3s as well as voice recordings? Quote
Ekona Posted January 22, 2010 Posted January 22, 2010 There probably already is if you jailbreak it. Quote
yokomo Posted January 22, 2010 Posted January 22, 2010 it can already , if you have a BT headunit then select Bt audio as your source and if the iphone is paird it will switch to ipod mode and play ! Quote
Bradders Posted January 27, 2010 Posted January 27, 2010 it can already , if you have a BT headunit then select Bt audio as your source and if the iphone is paird it will switch to ipod mode and play ! What's a BT headunit? Sorry newb only got my Z last Saturday. Still can't pair mine. Searched forum but no joy. Is there a guide? Thanks Bradders Quote
M13KYF Posted January 27, 2010 Posted January 27, 2010 it can already , if you have a BT headunit then select Bt audio as your source and if the iphone is paird it will switch to ipod mode and play ! What's a BT headunit? Sorry newb only got my Z last Saturday. Still can't pair mine. Searched forum but no joy. Is there a guide? Bradders a aftermarket headunit with bluetooth built in manuals here viewtopic.php?f=35&t=8312&hilit=+manual tells you all you need to know Quote
