Thomas Posted January 21, 2010 Share Posted January 21, 2010 Looking to replace the lid on my cubby hole as its a bit scratched up and found this; http://www.jdmperformance.co.uk/item_de ... odID=57881 my cars a uk spec 350GT on an 04 plate and it has a non retractable lid on the cubby hole, would this fit my car and if so would it match the colour of my dash? Cheers Tom Quote Link to comment Share on other sites More sharing options...
Husky Posted January 21, 2010 Share Posted January 21, 2010 the motorised one!!!! bladesgrant has this on his JDM from new and i was very very jealous! hmmmmm. looks good though mate Quote Link to comment Share on other sites More sharing options...
gunmetalzgt Posted January 21, 2010 Share Posted January 21, 2010 It might not work because surely it need something to tell it when to open and close? us uk owners wont have this. on the other hand it could be quite simple and connect to ignition live. someone on here probably knows.... Quote Link to comment Share on other sites More sharing options...
speedy Posted January 21, 2010 Share Posted January 21, 2010 I don’t think it is motorised like the one you are talking about husky…this looks the same as the unit the Nurrish uses for his sat navs (I have one). Plus is looks a little cheap for a motorised unit. The door automatically retracts when you press the button. Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 21, 2010 Share Posted January 21, 2010 It is NOT motorised...the motorised cubby it totally different Quote Link to comment Share on other sites More sharing options...
Husky Posted January 21, 2010 Share Posted January 21, 2010 It might not work becuase surely it need something to tell it when to open and close? us uk owners wont have this. on the other hand it could be quite simple and connect to ignition live. someone on here probably knows.... its the front button that tells it to open/close mate all it needs is the power feed. not sure where it would plug in, but as you say its not a hard job to add one in EDIT: it says motorised track and movement, in the pic it has a power connector so confused :S Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 21, 2010 Share Posted January 21, 2010 Also you will need the finisher plate other wise you will have a open space.....jdm dont sell this item....be careful to as i had to wait nearly 5 weeks for one to be delivered...they dont hold them in stock and they order from japan Quote Link to comment Share on other sites More sharing options...
speedy Posted January 21, 2010 Share Posted January 21, 2010 Nurrish, is this the same one as you use? Can you motorise it my providing power and earth to the white little box at the back of the unit? Quote Link to comment Share on other sites More sharing options...
Husky Posted January 21, 2010 Share Posted January 21, 2010 whats the white connector in the piccy then? Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 21, 2010 Share Posted January 21, 2010 you cant motorize these units.....i have looked at the motorized ones and there is alot more electrics to it....that connector on that one is purely a switch for something else....its not even connected to anything on uk cars Quote Link to comment Share on other sites More sharing options...
dcash5 Posted January 21, 2010 Share Posted January 21, 2010 Oh dear guys!..... The white plug is for the OEM sat nav screen, its a small switch that is activated by the cubby sliding back to power up the screen. The motorised part actually mechanical, its basically a tensile metal band - to close it you have it pull the thing back Quote Link to comment Share on other sites More sharing options...
speedy Posted January 21, 2010 Share Posted January 21, 2010 Oh dear guys!..... The white plug is for the OEM sat nav screen, its a small switch that is activated by the cubby sliding back to power up the screen. The motorised part actually mechanical, its basically a tensile metal band - to close it you have it pull the thing back Just thought Nurrish, if the above is correct is there some way of using this function to power your unit when it opens? Quote Link to comment Share on other sites More sharing options...
Husky Posted January 21, 2010 Share Posted January 21, 2010 Oh dear guys!..... The white plug is for the OEM sat nav screen, its a small switch that is activated by the cubby sliding back to power up the screen. The motorised part actually mechanical, its basically a tensile metal band - to close it you have it pull the thing back Just thought Nurrish, if the above is correct is there some way of using this function to power your unit when it opens? +1 are the ones supplied with yours the same thing? Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 21, 2010 Share Posted January 21, 2010 I have thought about this.....but because the system needs a long push to turn on it wont work....it would be feesable though to put it into sleep mode and for it to wake up....but if the battery was to die there would be no way to turn it on Quote Link to comment Share on other sites More sharing options...
dcash5 Posted January 21, 2010 Share Posted January 21, 2010 Dont think so as this is a constant connection rather than a momentary 2 seconds required for the 'Nurrish Special'. I tried using this when I built mine. Would require a relay small circuit board to make it momentary unfortunately Quote Link to comment Share on other sites More sharing options...
Husky Posted January 21, 2010 Share Posted January 21, 2010 so its possible then, just needs a wee circuit attached nice to know, thanks guys Quote Link to comment Share on other sites More sharing options...
R35LEE Posted January 21, 2010 Share Posted January 21, 2010 I have a uk unmarked cubby for sale if you want one Quote Link to comment Share on other sites More sharing options...
Thomas Posted January 21, 2010 Author Share Posted January 21, 2010 How much do you want for it mate. Quote Link to comment Share on other sites More sharing options...
