bhavin85 Posted January 19, 2010 Share Posted January 19, 2010 hey guys, Bennett was over this weekend to drop off my Berks HFC's, was an absolute pleasure meeting him Just a few questions....i was watching this guide and it talks about having to get at bolts in the engine bay for the HR engine...is that the same for the revup or are all the bolts on the bottom? http://autohow.tv/z/how-to-install-350z-hfc-test-pipes Secondly - I didnt get a gasket with the HFC's, should I jsut get another from Nissan or 1 of the traders on here? or do you think the one currently on there would be ok? the car is an 06. Cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 19, 2010 Share Posted January 19, 2010 Triangle gaskets are £20.00 each but you should be able to reuse your old ones. I have them in stock if you find that you require them. viewtopic.php?f=38&t=31540 Quote Link to comment Share on other sites More sharing options...
bhavin85 Posted January 22, 2010 Author Share Posted January 22, 2010 Thanks Alex...ill let you know on Monday if I need them Anyone know about the bolts? do they need to be accessed via the engine bay? or are they all under the car? Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 22, 2010 Share Posted January 22, 2010 If you dont mind a bit of contortion then you can get access to all the bolts from under the car...i removed both wheels which makes it easier Quote Link to comment Share on other sites More sharing options...
