GUIDE: Resetting Airbag Warning light
Jacko
In the event of having a flashing Airbag warning light (but with no fault with the system), then follow the following procedure:
This procedure will CLEAR the AirBag light ONLY if you do not have problems with the airbags on your 350Z.
1. Turn ignition switch from OFF to ON.
2. Air Bag warning lamp is on for 7 seconds and turns off, then turn ignition switch OFF within 1 second after the lamp turn off.
3. After ignition switch is turned OFF, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice. (Perform 3 times in total.)
5. Turn Ignition switch ON.
6. The SRS lamp has been reset it.
In the event that this does not work, then may be indicative of an actual fault and further investigation should be sought.
