yokomo Posted January 13, 2010 Share Posted January 13, 2010 if your just wanting to add some bass and ditch the bose sub/POS then yes id go for a monoblock of about that power , as for sub it depands on how creative you are on install. if you dont mind pulling the rear panel apart you can get the bose plate out and 10inch can be fitted in there(search for box design as its been posted ). Quote Link to comment Share on other sites More sharing options...
Burnsidea Posted January 13, 2010 Author Share Posted January 13, 2010 if your just wanting to add some bass and ditch the bose sub/POS then yes id go for a monoblock of about that power , as for sub it depands on how creative you are on install.if you dont mind pulling the rear panel apart you can get the bose plate out and 10inch can be fitted in there(search for box design as its been posted ). do I need to all this anyway like I said I had bass with the sub with the standard unit now I have changed i cant get the sub to work as sub works as a rear Also what is this like any good? http://cgi.ebay.co.uk/JBL-GT5-A3001E-Mo ... 3ca2717e88 Quote Link to comment Share on other sites More sharing options...
yokomo Posted January 13, 2010 Share Posted January 13, 2010 looks ok , runs down to 1ohm which rare too. not sure why the bose sub isnt working though , little strange that. Quote Link to comment Share on other sites More sharing options...
Burnsidea Posted January 13, 2010 Author Share Posted January 13, 2010 looks ok , runs down to 1ohm which rare too.not sure why the bose sub isnt working though , little strange that. It does work but only like the rears. does not have the low range that it should have. Also what sub would you get not to high in price... If I wanted to run all off a amp how is this one? http://cgi.ebay.co.uk/6000WATT-5-4-3-2- ... 33592035dc Quote Link to comment Share on other sites More sharing options...
yokomo Posted January 13, 2010 Share Posted January 13, 2010 erm not heard of them before , same kind of budget .. http://www.caraudiodirect.co.uk/infinit ... -475a.html infinity stuff tends to be pretty good and packs a decent output for the size. id get a listen to a Z with just the blose + proper sub first as unless your pretty handy with ICE type stuff its alot of extra wiring (main reason i couldnt be botherd and im not to bad at it) but hvaing said that you could buy the amp and a sub then if see how it goes. http://www.caraudiodirect.co.uk/jbl-gto1014.html thats 10 and the jbl budget subs tend to get good value for your money ratings. Quote Link to comment Share on other sites More sharing options...
Burnsidea Posted January 13, 2010 Author Share Posted January 13, 2010 erm not heard of them before , same kind of budget ..http://www.caraudiodirect.co.uk/infinit ... -475a.html infinity stuff tends to be pretty good and packs a decent output for the size. id get a listen to a Z with just the blose + proper sub first as unless your pretty handy with ICE type stuff its alot of extra wiring (main reason i couldnt be botherd and im not to bad at it) but hvaing said that you could buy the amp and a sub then if see how it goes. http://www.caraudiodirect.co.uk/jbl-gto1014.html thats 10 and the jbl budget subs tend to get good value for your money ratings. Thanks for that prob get that amp and sub and just leave it at that till i want more speakers hooking up Quote Link to comment Share on other sites More sharing options...
Burnsidea Posted January 13, 2010 Author Share Posted January 13, 2010 erm not heard of them before , same kind of budget ..http://www.caraudiodirect.co.uk/infinit ... -475a.html infinity stuff tends to be pretty good and packs a decent output for the size. id get a listen to a Z with just the blose + proper sub first as unless your pretty handy with ICE type stuff its alot of extra wiring (main reason i couldnt be botherd and im not to bad at it) but hvaing said that you could buy the amp and a sub then if see how it goes. http://www.caraudiodirect.co.uk/jbl-gto1014.html thats 10 and the jbl budget subs tend to get good value for your money ratings. Oh and can that amp do all 5 speakers? Quote Link to comment Share on other sites More sharing options...
yokomo Posted January 13, 2010 Share Posted January 13, 2010 4 chan so no , i would sugest you run the front pair off it ,bridge the rear chan for the sub and leave the rear speakers alone . Quote Link to comment Share on other sites More sharing options...
Burnsidea Posted January 13, 2010 Author Share Posted January 13, 2010 4 chan so no , i would sugest you run the front pair off it ,bridge the rear chan for the sub and leave the rear speakers alone . sweet cheers Quote Link to comment Share on other sites More sharing options...
