nurrish Posted January 7, 2010 Share Posted January 7, 2010 Here is a picture of the fuel pump assembly What i need to know is......does the main fuel line connect to the nossel ontop? Im fairly sure it does...just need confirmation Quote Link to comment Share on other sites More sharing options...
P15UL T Posted January 7, 2010 Share Posted January 7, 2010 is that not where you removed it from when you stripped it Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 7, 2010 Author Share Posted January 7, 2010 is that not where you removed it from when you stripped it Yeah......but there is a connection that is on the inside of the tank too... Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted January 7, 2010 Share Posted January 7, 2010 connection on inside is connected to a black flexi hose that comes from the passenger side of the fuel tank. Only 1 pipe outside the tank that needs fitting. I dont think the pipe inside would fit on the feed pipe 1,the inner pipe is much smaller and 2,it,s not long enough 3, it will get crushed when you bolt the pump back down. hope that helps you must be getting near to run the old girl!!!!!! Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 7, 2010 Author Share Posted January 7, 2010 connection on inside is connected to a black flexi hose that comes from the passenger side of the fuel tank. Only 1 pipe outside the tank that needs fitting. I dont think the pipe inside would fit on the feed pipe 1,the inner pipe is much smaller and 2,it,s not long enough 3, it will get crushed when you bolt the pump back down. hope that helps you must be getting near to run the old girl!!!!!! Thank you Yup nearly ready to be fired up The reason why i asked this is because i am looking to run a new fuel line to get rid of the connection between where the new fuel line meets the stock line....i am not 100% on the join I have been looking at steel braided lines....what would you suggest? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted January 7, 2010 Share Posted January 7, 2010 braided steel lines are good , but only if you use the proper re-usable connections , used with jubilee clips itlooks is pants. I would run the extra return line in high pressure rubber pipe ( fuel injection pipe) , easier to work with less agressive when it is contact with other pipes/wiring. Mark Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 7, 2010 Author Share Posted January 7, 2010 braided steel lines are good , but only if you use the proper re-usable connections , used with jubilee clips itlooks is pants. I would run the extra return line in high pressure rubber pipe ( fuel injection pipe) , easier to work with less agressive when it is contact with other pipes/wiring. Mark My return line is rubber....its just the main line i am concerned about...i dont mind using jubilee clips and dont care how it looks aslong as they do the job Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted January 7, 2010 Share Posted January 7, 2010 but I will, care when I see it..... Quote Link to comment Share on other sites More sharing options...
nurrish Posted January 7, 2010 Author Share Posted January 7, 2010 but I will, care when I see it..... So a jubilee clip should secure it to the plastic nossel on the fuel assembly? i will make it look pretty Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted January 7, 2010 Share Posted January 7, 2010 Perhaps a nicely anodised jubilee clip? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted January 8, 2010 Share Posted January 8, 2010 You can get the alloy cover jubilee clips they look better, it is just the braided hose is hard work to work with , the braided cover un-ravels , causing cut fingers and hands, also the stainless braided covering works like a file when it rubs agaisnt other materials , seen it wear throu alloy casings/radiators etc etc , all need isolating from rubbing anything. Mark Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 8, 2010 Share Posted January 8, 2010 Are said braided hoses not covered then? All braided lines I've had for cars/bikes have always had a silicone like cover on them. I assume these lines you are talking about are bare, in which case, as Mark said, any abbrasion will wear through other stuff and also when it wears the braid itself it will fray and be a nightmare Quote Link to comment Share on other sites More sharing options...
