johnnywas Posted January 11, 2010 Share Posted January 11, 2010 go to www.frost.co.uk and look up a product called air dry,it helps to keep the inside of the car dry . Quote Link to comment Share on other sites More sharing options...
alessandro Posted January 11, 2010 Share Posted January 11, 2010 Make sure the air is set to come from outside and not recirculating inside. That causes bad condensation if left like it too long as well. I was keeping the air set on recirculating and was a nightmare, now it's set on the outside bit and most time it's ok even without the air-con on Quote Link to comment Share on other sites More sharing options...
Stew Posted January 11, 2010 Share Posted January 11, 2010 That air dry stuff looks good. http://www.frost.co.uk/item_Detail.asp? ... =Air%20Dry Quote Link to comment Share on other sites More sharing options...
Rentech Posted March 4, 2010 Share Posted March 4, 2010 With recirc on , as other have said, condensation will be a problem. I wouldn't go with the line that you need air con on all the time though . Unless you've got a source of damp inside the car eg sports kit or wet coat then it shouldn't be needed apart from for a quick front screen clear on a cold morning. Quote Link to comment Share on other sites More sharing options...
janz70 Posted March 4, 2010 Share Posted March 4, 2010 a source of damp like your warm moist breath hitting a cold window and condensing Quote Link to comment Share on other sites More sharing options...
