alessandro Posted December 21, 2009 Share Posted December 21, 2009 Got in the car this morning and found the wind screen ice up on the INSIDE, not much but never had this before in a car, is this normal? Pick up the car tonight ( or tried too anyway) and no ice on the inside but there was some condesation forming small drops of water on the inside of the rear window.... Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted December 21, 2009 Share Posted December 21, 2009 Turn the AC on... Its not just for cold air! And dont use the recyle setting! Quote Link to comment Share on other sites More sharing options...
alessandro Posted December 21, 2009 Author Share Posted December 21, 2009 I turn the A/C on, but I never experience ice on the inside of the car, but didn't know about the recycle bit Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted December 21, 2009 Share Posted December 21, 2009 Lots of moisture in the air, cold temp makes it freeze. Possible due to you getting into the car wet, or with snow o your feet. It evaporates while you drive and then the condensation freezes while your parked up. The air con on with the temp on hot will work like a de humidifier. And the recycle air function is the button on the middle of he central dial. Either air brought in from outside, or air recirculated from inside. The little picture on the button should explain it for you. Quote Link to comment Share on other sites More sharing options...
alessandro Posted December 21, 2009 Author Share Posted December 21, 2009 Lots of moisture in the air, cold temp makes it freeze. Possible due to you getting into the car wet, or with snow o your feet. It evaporates while you drive and then the condensation freezes while your parked up. That explain it, thanks, still, found it weird because never had this before in any car, I was worried that something to do with the "insulation" or something Thanks Quote Link to comment Share on other sites More sharing options...
