ug45cwb Posted December 17, 2009 Share Posted December 17, 2009 Recently had a nismo kit fitted and the side skirts seem to cover up the jack points so I cant fit my new wheels. I believe there is another jack point in the centre but I don't have the correct jack for it. I would happily pay a local garage for fitting but how the hell am I going to get the wheels there? Quote Link to comment Share on other sites More sharing options...
martinmac Posted December 17, 2009 Share Posted December 17, 2009 I am not sure about the nismo but with the Ings I just drive the car onto some wooden blocks, the jack can then clear the skirts and lift on the original jacking points. Quote Link to comment Share on other sites More sharing options...
Husky Posted December 17, 2009 Share Posted December 17, 2009 Recently had a nismo kit fitted and the side skirts seem to cover up the jack points so I cant fit my new wheels. I believe there is another jack point in the centre but I don't have the correct jack for it. I would happily pay a local garage for fitting but how the hell am I going to get the wheels there? you can indeed fit 4 wheels, even 19's in the zed. i got 275 and 235 in there take spare tyre and boot mats out, one REAR under the strut bar one REAR over the strut bar sitting behind the headrests two fronts in the front seat sitting the same way as they would fit on the car, so side on, next to each other. if you angle them slightly toward the door it helps them from tipping. also you can wind the window down reach in and wrap a bungee round them and the passenger door handle to stop them falling on you. hope that helps. EDIT: when youve done it a few times it only take seconds tp get them in Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted December 17, 2009 Share Posted December 17, 2009 Go buy a trolly jack, one from Machine Mart is good... the aluminium one. Very useful... Easier than transporting wheels! You need at lease a 1.5 tonne one. Costco also do one... 2 jacking points under the centres, use the rear diff and there is spot just at the back of the front under tray. You may still need to go up on blocks to get the trolly jack underneath... Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted December 17, 2009 Share Posted December 17, 2009 Go buy a trolly jack, one from Machine Mart is good... the aluminium one. Very useful... Easier than transporting wheels! You need at lease a 1.5 tonne one. Costco also do one... 2 jacking points under the centres, use the rear diff and there is spot just at the back of the front under tray. You may still need to go up on blocks to get the trolly jack underneath... +1 Halfrauds do a 2.5tonne one pretty cheap as well, or at least they used to Quote Link to comment Share on other sites More sharing options...
IanS16 Posted December 17, 2009 Share Posted December 17, 2009 You can use the standard jack (from the boot) on the car with nismo sideskirts, thats what I use. Then use a trolley jack once the car is high enough. The skirts def dont cover the jack points. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted December 17, 2009 Share Posted December 17, 2009 You can use the standard jack (from the boot) on the car with nismo sideskirts, thats what I use. Then use a trolley jack once the car is high enough. The skirts def dont cover the jack points. Are they "flat" underneath on the nismo? I know on my chargespeed the jack points are recessed... Dosnt really matter as I cant get the OEM jack under them anyway! Which ever way I jack I need to go on blocks! Quote Link to comment Share on other sites More sharing options...
IanS16 Posted December 17, 2009 Share Posted December 17, 2009 You can use the standard jack (from the boot) on the car with nismo sideskirts, thats what I use. Then use a trolley jack once the car is high enough. The skirts def dont cover the jack points. Are they "flat" underneath on the nismo? I know on my chargespeed the jack points are recessed... Dosnt really matter as I cant get the OEM jack under them anyway! Which ever way I jack I need to go on blocks! Yep they are flat but skirts dont wrap round underneath enough to cover the jack points. In fact, I haven't found a jack yet that gets under the car without blocks other than the nissan OEM jacks. I did get a clio sport jack underneath it once but the jack bent Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted December 17, 2009 Share Posted December 17, 2009 We used the oem jack,then trolley jack once high enough last month to fit my wheels. Same sides as yours. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted December 17, 2009 Share Posted December 17, 2009 2 Nissan ones have failed on me now... Defo cant get the OEM jack under my skirts wayne... jack sits about 2cm too tall! Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted December 18, 2009 Share Posted December 18, 2009 I was referring to the op Mark. Quote Link to comment Share on other sites More sharing options...
ug45cwb Posted December 18, 2009 Author Share Posted December 18, 2009 Cheers for the help fellas..Polish guy came round and fitted them for me. Quote Link to comment Share on other sites More sharing options...
nixy Posted December 18, 2009 Share Posted December 18, 2009 they look gorgeous! Quote Link to comment Share on other sites More sharing options...
