AlexZ Posted December 15, 2009 Share Posted December 15, 2009 Evening people, just a quick one...When I wax oiled my car a little while back I noticed there was a little sutt around the rear back box to middle section. Does anyone know what type and size gasket this is??? I'm guessing its a metal woven ring gasket or compression ring. I would like to replace it rather then just using exhaust paste if I have to split the joint Alex Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 16, 2009 Share Posted December 16, 2009 Thinks its a metal ring. Quote Link to comment Share on other sites More sharing options...
Ebized Posted December 16, 2009 Share Posted December 16, 2009 Thinks its a metal ring. You think right Quote Link to comment Share on other sites More sharing options...
gunmetalzgt Posted December 16, 2009 Share Posted December 16, 2009 Its definately is. I just had mine done and there is rust on the neck of the join so a tiny bit of air passes by the gasket and ruins it. We used lots of exhaust gunk to stop this and all seems to be good now. Make sure yours isnt the same otherwise the gasket wont last long. its around 7 pounds from Nissan. Id get the nuts too if possible and the bolts are part of the backbox!! Good luck, hope this helps Quote Link to comment Share on other sites More sharing options...
AlexZ Posted December 16, 2009 Author Share Posted December 16, 2009 Thanks for the help guys...I'll get one sorted and see what happens. Alexz Quote Link to comment Share on other sites More sharing options...
