serious metal Posted December 14, 2009 Share Posted December 14, 2009 350Z Roadster - 2005 The roof gets stuck between the 9th and 10th operations - the 12th being when the lid closes! It has responded to a gentle push at this point, giving the impression that something is slightly out of shape or is out of alignment, but no longer. Are there any other soft top owners who have had this experience and found a self help solution? Quote Link to comment Share on other sites More sharing options...
choptop Posted December 14, 2009 Share Posted December 14, 2009 350Z Roadster - 2005The roof gets stuck between the 9th and 10th operations - the 12th being when the lid closes! It has responded to a gentle push at this point, giving the impression that something is slightly out of shape or is out of alignment, but no longer. Are there any other soft top owners who have had this experience and found a self help solution? Had this with my Roadster. Delearship sorted it out. Sorry cannot help further. Just one suggestion, is your battery fully charged? Quote Link to comment Share on other sites More sharing options...
martinmac Posted December 14, 2009 Share Posted December 14, 2009 There is an occasional issue with two of the struts getting sticky. They almost always respond to a bit of light greasing. If you search 350z tsb there is a full explanation of which ones are most prone to the problem. Welcome to the forum by the way. Quote Link to comment Share on other sites More sharing options...
rich5259 Posted December 14, 2009 Share Posted December 14, 2009 welcome to the forum, make yourself a thread in the intro's section and put some ohitis in as we like piccys here Quote Link to comment Share on other sites More sharing options...
maz77 Posted December 14, 2009 Share Posted December 14, 2009 this happens to mine if I dont open the top for long periods (couple of time last winter). I dont resolve to pushing instead just close it from that point and open it again. sounds like a greasing job as martin pointed out above Quote Link to comment Share on other sites More sharing options...
quicksilver Posted December 14, 2009 Share Posted December 14, 2009 I have'nt used mine for a month and had the same problem yesterday. It got to the last fold and stopped but I brought it up and back down and all was well. Is there a how to on the greasing or is it just a matter of putting some spray grease on all the joints? Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted December 15, 2009 Share Posted December 15, 2009 I have had the exact same as well. Just put it back up and then drop it again. Going to get mine all greased up soon although I don't think I will need it down anytime soon!!! Quote Link to comment Share on other sites More sharing options...
serious metal Posted December 15, 2009 Author Share Posted December 15, 2009 Thanks for your responses - its reasuring to know that this is a recognised fault, and probably fixable without main agents intervention! MartinMac - not sure what 350Z tsb is - sorry. Yes I will post some info and pics - over the hols. The 350Z is a totally standard 2005 Azure Blue with 15K miles - everyday transport is a much improved and remapped V70 T5 auto. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 15, 2009 Share Posted December 15, 2009 Technical Service Bulletin Quote Link to comment Share on other sites More sharing options...
stanski Posted December 15, 2009 Share Posted December 15, 2009 Seems a common problem - also the material stiffens up this time of year and motors need to work harder to close. Just ensure the roof is dry before you fold it. It will close eventually - you need to help it at first then grease up the arched rail at the back either side where the plastic rollers slide over it. Quote Link to comment Share on other sites More sharing options...
cavey Posted December 15, 2009 Share Posted December 15, 2009 my roof would not open fully today will try greasing tip hope it sorts problem out Quote Link to comment Share on other sites More sharing options...
martinmac Posted December 15, 2009 Share Posted December 15, 2009 My roof wouldnt open today, the dealer has flattened the battery. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 15, 2009 Share Posted December 15, 2009 My roof wouldnt open today, the dealer has flattened the battery. Oh Mart, whatever will we do with you! I think they owe you a 370z roadster as compensation Quote Link to comment Share on other sites More sharing options...
maz77 Posted December 15, 2009 Share Posted December 15, 2009 all of the above need to take their TOPLESS Zed's out tonight Quote Link to comment Share on other sites More sharing options...
