Beavis Posted December 13, 2009 Share Posted December 13, 2009 Got myself a small trickle/cycler charger for the zed today to keep the battery on its toes during the winter months. Says in the instructions to disconnect the battery before connecting. Do i really need to do this and what precautions should i take before i disconnect the battery?, dont really want to leave the windows powered down (recommended if you disconnect the battery) for long periods despite the fact the car is garaged and car covered. Quote Link to comment Share on other sites More sharing options...
Stew Posted December 13, 2009 Share Posted December 13, 2009 I have a 'permanant' trickle charger on my motorbike Dave. I didn't have to disconnect it and the fitting is fixed on. I've used a few trickle chargers and none have needed disconnected..... Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted December 13, 2009 Share Posted December 13, 2009 used one on my old roadster mr2 and i didn't disconnect the battery, but it switched itself on and off as required. Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 13, 2009 Author Share Posted December 13, 2009 Thanks for the replys guys To be honest i have had it on this afternoon with the battery connected and everything was fine. It comes with the fitted cable and plug anyway that you fit to the battery connections anyway. Thought it would be ok to connect with out disconnecting the battery, brother does the same on his Fezza Quote Link to comment Share on other sites More sharing options...
