Airbag warning light
SwanageDave
Help needed Please, got in the car today and the Airbag warning light is flashing away and i dont have a clue what could be wrong or how to turn the damned thing off, any ideas Chaps? H :rant: Hopefully Dave
Check under the seats for a bad connection on the wiring
Failing that then either fix it properly or fit a resistor. :thumbs:
  • 4 weeks later...
had this too.
Firstly try the reset as Renegade posted link.
Then check all connectors under seat, re-sit them.
Then if still fails it will be the loom in the rear part of the seat. Happened on mine. It got crushed against the frame of the seat. Had the crused but cut out and re-soldered back together. Garage identified my problem. Cost £45 to repair.
Resistor as Alex pointed out will turn off the light but also keep the airbag turned off.
