SwanageDave Posted December 13, 2009 Share Posted December 13, 2009 Help needed Please, got in the car today and the Airbag warning light is flashing away and i dont have a clue what could be wrong or how to turn the damned thing off, any ideas Chaps? H Hopefully Dave Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 13, 2009 Share Posted December 13, 2009 Help needed Please, got in the car today and the Airbag warning light is flashing away and i dont have a clue what could be wrong or how to turn the damned thing off, any ideas Chaps? H Hopefully Dave Check under the seats for a bad connection on the wiring Failing that then either fix it properly or fit a resistor. Quote Link to comment Share on other sites More sharing options...
ChrisS Posted December 13, 2009 Share Posted December 13, 2009 Beaten by 4 mins by Alex. If it is the connector under the seat,a small tie wrap fixed mine. Used to happen after moving the seat back and forth... Quote Link to comment Share on other sites More sharing options...
Renegade Posted December 13, 2009 Share Posted December 13, 2009 Try the reset it works for me. viewtopic.php?t=3279 Quote Link to comment Share on other sites More sharing options...
SwanageDave Posted December 14, 2009 Author Share Posted December 14, 2009 Tried the reset ...and it worked.. Thank you all for the advice And A Very merry Xmas to you all Quote Link to comment Share on other sites More sharing options...
Roo Posted January 7, 2010 Share Posted January 7, 2010 Love this place --- same problem on mine though think itwas cuased by a lass dropping some sort of girly thing which slid under the seat. Did the reset. Warning light went off and stayed off. Go team!!! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 7, 2010 Share Posted January 7, 2010 had this too. Firstly try the reset as Renegade posted link. Then check all connectors under seat, re-sit them. Then if still fails it will be the loom in the rear part of the seat. Happened on mine. It got crushed against the frame of the seat. Had the crused but cut out and re-soldered back together. Garage identified my problem. Cost £45 to repair. Resistor as Alex pointed out will turn off the light but also keep the airbag turned off. Quote Link to comment Share on other sites More sharing options...
