Short shift gear stick thing, install or sell?
Mark-UK
As i said...on the highest setting its actually better than stock for town driving...gearchange is not tight any more even when cold...
on lowest setting its bad...but once warm enough good fun!!!! :teeth:
not seen one with variable settings before, got a link to what your using.
i previously had a B&M short shifter kit fitted to my MR2 and it was one setting only. shorter :lol: as it reduced the height of the gear lever.
does this mean your gear lever is telescopic or something?
An extendable gearstick.
My my...
lol works in reverse, gets shorter the more excited you get. its the anti- erection :lol:
:lol::lol::lol:
yes its got 4 settings...higher than oem...same as oem... shorter...too short to be any good!!! :lol:
its got an inner ring with a spring that you lift up and then you chose the setting...and you can do it whilst at a traffic light!!!
its quite good!
just dont forget to grease the plastic ball cos it squeaks like mad on cold weather!!! :)
