Head Lamp Bulbs
flirt
Where do you lot get your headlamp indicator (Silver or clear) bulbs from! The ones I got sold are wrong!! good job i didnt strip the wheel arch off :)
Oh and btw, you don't need to take out the wheel arch. Just undo the top bolt holding in the headlight. This gives you enough leeway to get your fingers in, twist off the locking holder, then if needs be use some needle nose pliers to twist the wire around so you can change the bulb....
Easy..... just have some patience ;)
