Blacky Posted July 27, 2006 Share Posted July 27, 2006 I was just doing a bit of research,when I came across this. or there is a trick... turn the car to the ON position.. not with the motor running just on... roll the car back 15 feet, roll the car forward 15 feet... this should re-calibrate your VDC system Has anyone tried this. Could be useful if your changing from standard wheels/tyre sizes Quote Link to comment Share on other sites More sharing options...
lomoto Posted July 27, 2006 Share Posted July 27, 2006 I was just doing a bit of research,when I came across this. or there is a trick... turn the car to the ON position.. not with the motor running just on... roll the car back 15 feet, roll the car forward 15 feet... this should re-calibrate your VDC system Has anyone tried this. Could be useful if your changing from standard wheels/tyre sizes Where did you find this snippet Blacky?? Quote Link to comment Share on other sites More sharing options...
Blacky Posted July 27, 2006 Author Share Posted July 27, 2006 I was just doing a bit of research,when I came across this. or there is a trick... turn the car to the ON position.. not with the motor running just on... roll the car back 15 feet, roll the car forward 15 feet... this should re-calibrate your VDC system Has anyone tried this. Could be useful if your changing from standard wheels/tyre sizes Where did you find this snippet Blacky?? Found it ona thread on MY350Z.COM, good source as well Andy at performance Nissan. Be interested to hear if it works, could be useful as I know people have posted here with imports that don't have standard wheels/tyres. Quote Link to comment Share on other sites More sharing options...
lomoto Posted July 27, 2006 Share Posted July 27, 2006 be nice to see if it works sounds plausible enough Quote Link to comment Share on other sites More sharing options...
Jacko Posted July 27, 2006 Share Posted July 27, 2006 Mmmm that might be interesting once get different wheels on..... I suppose the only thing, is how the hell do you know if its made a difference. Will be all subjective? But worth a try.... You doing it tomorrow Blacky when your wheels turn up? Quote Link to comment Share on other sites More sharing options...
Gus Posted July 27, 2006 Share Posted July 27, 2006 This was mentioned a couple of years back on the old site - can't recall if anyone confirmed whether it worked or not Gus Quote Link to comment Share on other sites More sharing options...
Blacky Posted July 27, 2006 Author Share Posted July 27, 2006 Mmmm that might be interesting once get different wheels on..... I suppose the only thing, is how the hell do you know if its made a difference. Will be all subjective? But worth a try.... You doing it tomorrow Blacky when your wheels turn up? Not fitting wheels till Wednesday. But hopefully won't be any problems with TCS with my tyre choices. Quote Link to comment Share on other sites More sharing options...
