witstu Posted November 27, 2009 Share Posted November 27, 2009 After just reading and looking at pictures of another members woes of fitting wheel spacers,from the rust marks they appear to be mild steel? are any of the wheel spacer manufacturers making non rusting alloy lightweight ones? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 27, 2009 Share Posted November 27, 2009 After just reading and looking at pictures of another members woes of fitting wheel spacers,from the rust marks they appear to be mild steel? are any of the wheel spacer manufacturers making non rusting alloy lightweight ones? You will find that most quality spacers are manufactured from High Strength Aircraft-Aluminium Alloy with extreme corrosion protection through DIN 50021 approved coating process. Quote Link to comment Share on other sites More sharing options...
SunGodRA Posted November 27, 2009 Share Posted November 27, 2009 I concur Dr Alex - just to clarify, DIN 50021 refers to: This standard specifies the requirements which corrosion testing apparatuses and corrosive agents must meet in salt spray testing, the aim being to enable identical conditions to be reproduced in all cases in which spray tests are carried out on the basis of standards or agreements. The standard does not deal with the preparation of specimens, the duration of testing, the treatment of specimens after testing, or the evaluation of results. Which of the three methods listed in clause 3 is to be applied in any individual case shall be the subject of agreement between the parties concerned unless specified in relevan standards. The tests described in this standard serve both to characterize the effectiveness of corrosion protection systems and to detect defects quickly. They are not suitable for specifically testing for defects in metallic coatings where the coating is made of a baser metal than the substrate (e.g. zinc or aluminium on steel), since the substrate is in such cases cathodically protected by the coating adjoining the defect. oops, Tramadol time! Quote Link to comment Share on other sites More sharing options...
gunmetalzgt Posted November 27, 2009 Share Posted November 27, 2009 i've got eibach ones on mine and they are spot on CS has them in stock i believe. Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 28, 2009 Share Posted November 28, 2009 Yep, can't go wrong with Eibach, which thankfully nearly everyone on here use: http://z-store.co.uk/index.cfm?fuseacti ... ct_ID=9316 Quote Link to comment Share on other sites More sharing options...
Husky Posted November 28, 2009 Share Posted November 28, 2009 Yep, can't go wrong with Eibach, which thankfully nearly everyone on here use: http://z-store.co.uk/index.cfm?fuseacti ... ct_ID=9316 even i didnt bugger them up Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 30, 2009 Share Posted November 30, 2009 Yep, can't go wrong with Eibach, which thankfully nearly everyone on here use: http://z-store.co.uk/index.cfm?fuseacti ... ct_ID=9316 even i didnt bugger them up They must be dead easy to fit then Quote Link to comment Share on other sites More sharing options...
jerry3167 Posted December 1, 2009 Share Posted December 1, 2009 Even a sceptic like me has the Eibach spacers!! Quote Link to comment Share on other sites More sharing options...
