Rossz1 Posted November 24, 2009 Posted November 24, 2009 Hi guys does anyone no which side B1 camshaft position sensor is because it seems a relatively easy job to do. so i just need to no which side B1 is. my error code was P0340 camshaft position sensor B1. i have given up on the steering issue Cheers Quote
Rossz1 Posted November 25, 2009 Author Posted November 25, 2009 Sorry to mither but in the instructions you put up for changing the sensor the driver side is our passenger side so do i fit the new sensor on our drivers side but follow the instructions for passenger side? Quote
ZMANALEX Posted November 25, 2009 Posted November 25, 2009 Sorry to mither but in the instructions you put up for changing the sensor the driver side is our passenger side so do i fit the new sensor on our drivers side but follow the instructions for passenger side? Not sure what instructions you are referring to but if they are for are a LHD car then the answer to your question is Yes. Quote
Rossz1 Posted November 26, 2009 Author Posted November 26, 2009 http://maxima.theowensfamily.com/tsb/NTB03-124.pdf sorry that was the link im reading on how to install it Quote
