Project Nurrish: Vortech Supercharger
nurrish
  clarkie34 said:
Rather you than me,i would not have the patience to do it.
I take it with this setup you don't need a hideous bonnet?
Yeah no whacky bonnet required :lol:
But seriously this job is not for the faint hearted....the pipe down into the engine bay has about 1mm of room to move to get it to fit.....i resorted to a long file and a mallet :bangin: Then you have to align it to the pipe underneath....needs to be **** on otherwise you wont get a correct fitment and lead to leakages
  • Replies 138
  • Created
  • Last Reply
Top Posters In This Topic
So this is probably the last update until i receive more bits....waiting on my AAM Fuel kit and walbro 255 pump.
Broke the back of the job this weekend by getting the blower mounted and the pipes sorted ready to fit straight into my engine intake. This week i will probably get the belts on the stock cogs and onto the blower block...
This leaves me to fit my injectors,oil cooler, larger oil pan, spark plugs, fuel rails, fuel return and fuel pump....Then she's getting 6 litres of the finest oil...plug in my utec and away she goes :) fingers crossed :scare: O and remember where all these random bolts i have laying around have come from :bangin:
Anyway last pic's as it is now having sold my carbon bonnet
:thumbs:
Nice one! Well done for going down this road, where did you get the:
AAM Fuel kit and walbro 255 pump < from?
Looking forward to reading about the fitting of that :) (looking to get that myself start of next year)
:snack:
The video of the kit fitted from str8dum's channel sounds sick! :band:
Didn't realise there was still so much to do :scare:
Going to be a busy christmas break :D
Drain Oil
Mount oil cooler and run piping
Refill Oil
Install belts
Fit Fuel Rails
Fit Injectors
Fit Fuel Pump
Route Fuel Return System
Mount Utec ECU
Tap Plenum
Run pipe from BPV to plenum
Run utec boost sensor to plenum
Install aem gauge
install boost gauge
Fit spark Plugs
Reassemble
Mount mesh in front bumper
Fit exhaust
Tune
  Husky said:
noob question, tapping the plenum involves? can you not use the spare breather at the front?
With my setup i need to run atleast 3 valves into the plenum...the easiest route is to take a t off the nipple...but this could lead to problems and incorrect readings...so to tap the plenum is to add more nipples!
  nurrish said:
  rtbiscuit said:
adam at z1auto does a plenum spacer with built in valves ready for fitting gauges onto. might even work for tapping the plenum.
O really? i shall go and have a butchers
have a search for my threwad on here about plenum spacers, think it will only throw the one result, has links to all items mentioned, and i think it has 3 nipples for about 3 gauges, or it might be 2 :blush:
