Project Nurrish: Vortech Supercharger
nurrish
Project Nurrish - Vortech Supercharger v-3
Vortech V-3 self contained supercharger with SI trim impeller upgrade
UTEC EMS with MAP sensor
Deatschwerks 600cc injectors
Monster 24x12x4" Core Intercooler
Vortech Race Bypass valve
My Extra's:
Got:
Walbro 255 Fuel Pump
Plenum Spacer
100cell Race Cats
AAM Stage 1 Fuel Return System Inc Fuel Rails
Hel Oil Cooler
Spark Plugs
Boost Gauge
AEM wideband Gauge
Motul Oil
Oil Filter
Grill Mesh
Mishimoto Radiator
AAM Throttle Body Spacer
AAM Oil Pan Spacer
Oil Catch Can
Breather Filter
Dual Exhaust
10l of Motul Radiator Fluid
Jobs left to do:
Tune :yahoo:
Build Begins:
Earlier this week i removed my Kinetix Plenum, AEM CIA and my K1 Exhuast
21/11/2009 - Removed Cats and Y-pipe. I somehow managed to take my cats off by jacking the car up high enough and taking off my passanger wheel. This revealed the manifolds/cat connection...a bit of contortion and huzzzah they came off!! Actually cant believe how heavy they are :bangin:
23/11/09- Stripped
28/11/09
Comments can be added here
viewtopic.php?f=20&t=30353&p=438398#p438398
  • Replies 138
  • Created
  • Last Reply
Top Posters In This Topic
hmm taking off the wheel, must be a better option then going through the engine bay like I did to get those babes out! :teeth: They all look in pretty darn good condition though & the Y pipe!.
Whats your project time like? :thumbs: (that might give some hint to what you want to do)
:snack:
Im hoping to be finished with the main bits before Christmas but i wont be driving anywhere until February at the earliest.....mainly due to not having any wheels/exhaust system :lol::lol: I am hoping to collect these bits the early part of next year
If its FI, why the sudden about turn? Why do all you've done and then decide to undo it all so suddenly? :blush:
I've kept the aesthetics of my car intact....just sold wheels and seats. Thats to Gordon (greido) he has borrowed me a set of 17's to get by with :thumbs:
But after seeing alex's place yesterday this is childs play :lol:
Seriously though i dont think i have met a nicer person than alex. So welcoming and very friendly :thumbs: Absolute top man and plus he owns such an immense beast :cloud9:
Plus amended title in reflection to the thread :boxing:
So here is whats going on my car....
Here is what the previous owner got out of it...he was however running a fuel return and meth inject system which i wont be doing..should be interesting what i get out of it
Soooooo....... Super charger arrives tuesday :yahoo::bounce:
Things i need to sort out:
Walbro 255 Fuel Pump - Brought
Exhaust Inc Ypipe - Need
Plenum - Got
Spacer - Brought
HFC - Got
Seats - Need
Gauges - Need
Fuel Management Unit - Do i need?
Uprated Fuel rails - Do i need?
Hmmmm anything else needed? :bangin:
Dave, My Vortech shopping list was
Vortech Supercharger Kit
Defi Boost Gauge
Defi Oil Temp Gauge
Defi Oil Pressure Gauge
Defi Control Unit
AEM Wideband Gauge
Denso Spark Plugs
Deatschwerks 600CC injectors
Koyo 36MM Radiator
AAM Oil Pan Spacer
Cosworth Plenum (Baller feature) ;)
3.12 & 3.33 pulleys
Might be worth getting some headers aswell while your at it.
I think that was about it :teeth:
I have now sorted my gauges with a awesome all in one solution :ninja:
got the injectors coming
so from your list all i would need is the radiator and oil pan
I'm not sure they are essential items but if your gonna do it, do it right the first time :)
I'd get a clutch & flywheel aswell, a Vortech will sound insane with a lightened flywheel B)
On my list too :D
Whats the top gauge?
When your wiring them in, disconnect the battery. I blew my ignition fuse because I didn't bother :blush:
this is from the seller
Boost gauge comes with its own map sensor that just needs power and ground, you then T into one of the vacuum hoses and run it to the sensor. very simple.
The Shift light comes with a tach adapter that taps into the coil wires for your RPM reference. Again, gauge just needs power and ground.
Air/Fuel comes with it's own oxygen sensor you can install or tap into your existing oxygen sensor wires. Power and ground for the gauge again.
Very nice mate....i had a few options to choose from such as the dm-200 but for value i went for the custom one...here is whats included
These gauges retail for the following:
Autometer Air Fuel $79
Autometer 02 Sensor- $30
Autometer Boost Gauge- $189
MSD Tach Driver- $80
Stewart Warner Shiftlight- $139
Custom Panel- $110
