Feeling flat...
helimeddaz
Hi All,
Right then, been away on mi hols for 2 weeks and today went to start the Z and guess what? Battery flat as a F%$3.
Now I would expect a bit of a drain over 2 weeks, but this is really flat and would not turn over the engine. I've had to go to work in the other car, Smart 4/2 (No Laughing) while the Z recharges. :bang:
My question is to our learned elders. Do we think think this is a normal drain or not. The Z was new 21st Feb this year and has had no issues to date with the battery or starting. :dry:
Booked it in for battery check Weds with the steelers. Always brings me out in a sweat when I have to get involved with them.
I suppose it's a matter of trust (Or lack of it).
No Tracker or drains I know of. when it's off it's off.
Any recommendations from my Yorkshire region owners for a good dealers service centre? A dealer with someone who knows something about 350's would be good.
Hope this is going to be simple...Dont want to go looking for trouble at this stage... Fingers crossed.. :thumbs:
Had a big Hi-fi install done months ago.. So cant see it being that or it would have gone sooner. :bang:
Ahhhhhhh....... this is a VERY important thing to mention.
The dealer will say it's down to this and it might well be.
How does that work? When you switch off the key the HI-Fi is all powered down! (No power cap for sub installed) I had exacly the same kit in a Civic type R will no issues at all. I know the stealers will look for any loophole they can, But a battery test will prove the battery good or not and then if thats ok, a power drain test with the ignition off will show any excessive drains beyond normal. I know all cars have some drain when turned off. ECU, Airbag system recycle checks and so on. I've left it stood for a week before with no issues. For once I hope I've been daft enough to have left something on (Interior light or something)
1 Thought I have had. When I took delivery the boot light did not work. When I noticed I polled the cover off to change the bulb as you would and found that the plug was not attached, so I plugged it back in and it worked. Never thought to check if it stayed on all the time and wouldn't see it as I have a tonneau cover fitted. Am I being paranoid or do you think the wires were off for a reason?
make sure the dealer checks the charge rate from the alternator - may not be an issue of losing charge...but that you aren't getting enough in the first place. My Zed is 5 yrs old and only battery issue was when I left the interior light on by mistake - amateur!
the dealer might have disconnected the light so it didn't drain the battery when the boot was open all day on the forecourt :thumbs:
Ah, Never thought of that. Mine was the last of their Z's and was the showroom car, but I bet thats was why it was off.
Left the Z at home all day on charge. I have a really good electronic charger which you can use while the battery is still connected to the car. It cycles and recycles the charge rate and then goes into "Flo" mode to maintain it once it registers full. Just taken it of charge and all seems ok. Off into Nissan Leeds Weds A.M. so I'll update once I've had their verdict.
Thanks for all the advice. As always top owners.. :thumbs::thumbs::thumbs:
Well... Here's the update!
Went to dealers today. Evans Halshaw Nissan (Leeds).
Asked for the Service Manager (Carl) and explained that this was a 1 shot deal and if they got this wrong or cocked up they would not see me come service time. I asked that he give the job card for my hard earned Z to his best man and was assured that this would happen, He said they had a 350 specialist.
Explained what had occured with the battery. He did feel that 2 weeks on a Z would not be unheard of for the battery to drain off and said that it needs 7 to 9 volts minimum to power up the systems before turning over the engine.
There is a work shop viewing window, so once my keys were handed over I positioned myself to watch. The Z was duly brought in and attached to the diagnostic kit. I saw the tech doing a number of checks with the machine and visually. He too about an hour in total.
When the tests were done the service manager came back to me and the verdict was that the battery was in fine fettle and the readings showed no excessive power "off" systems drain, even with my Hi-Fi install. The charging rate was within limits. He also said that the diagnostic had read the recorded the low battery episode from the cars memory (Don't know about that one). He said that was all they could do at this stage, but if I had any problems, book it back in and they would re-check it.
Overall I am satisfied with the Dealers checks and the Dealership was very helpful and listened to my concerns about my Z. I will consider them at service time. Although I may book it in and take my Ipod, a buttie and a flask and sit at the window and watch them (Like a hawk).lol
Not very trusting I know, But I worked hard for my pride and joy and take it personally if it's not given the TLC I deem fit. :teeth:
