Oil Pressure - warm tickover..?
Kuro
Guest prescience
Same as mine - absoultely fine. Will go up a bit after an oil change.
BTW the manual specifies 14 as the point at which to become concerned - as measured during a pressure test :)
different oil will give different reading. Mine currently hovers on the first mark when warm, previous oil was little over 0 when warm. Not sure what oil was in the previous time...
Just make suer you let it warm up, running it at 120psi aint doing it no favours ;)
Guest prescience
Good :) Mid-way between 0 and 30 is obviously 15 :lol: but that is the cut-off below which it is worth getting a pressure test done at the dealers. This is simple and it might just be the gauge in that situation anyway
