nurrish Posted November 8, 2009 Posted November 8, 2009 I am awaiting confirmation that this is possible. Im fairly sure it is and it will be plug and play. Its a UK ECU from a 2005 car with a UPREV Custom Map and Speed Delimited . Car was tuned at RSTuning. I believe it would just be a simple plug and play My setup was Kentix Plenum (pretty much same as a spacer) K1 Exhaust AEM Intake Looking for £280 with a swap for your ecu When you take into account the cost of the licence of the up rev software you will realise how cheap this is. You may just need an hour or so to custom tune it to your car Quote
givememorepower Posted November 8, 2009 Posted November 8, 2009 Wouldn't this require a re-map when fitted to another car, especially if they have different mods to you? Quote
nurrish Posted November 8, 2009 Author Posted November 8, 2009 Wouldn't this require a re-map when fitted to another car, especially if they have different mods to you? Well the map on there is setup for optimal performance on my car. May require a tune to get the best out of it but then again it might be just perfect. Quote
srobrien Posted November 8, 2009 Posted November 8, 2009 Do the ECU's on these not contain the immob codes? u may have to have it reprogrammed? Quote
nurrish Posted November 8, 2009 Author Posted November 8, 2009 Do the ECU's on these not contain the immob codes? u may have to have it reprogrammed? Not sure there mate.....me and ians16 replaced his ecu with the nismo tuned one and it was a straight swap....... Quote
srobrien Posted November 8, 2009 Posted November 8, 2009 Do the ECU's on these not contain the immob codes? u may have to have it reprogrammed? Not sure there mate.....me and ians16 replaced his ecu with the nismo tuned one and it was a straight swap....... Hmm probably not then Quote
Grantmitchell Posted November 20, 2009 Posted November 20, 2009 NOW FOR SALE Updated 1st post Will this work in a 2003 car?? Quote
nurrish Posted November 20, 2009 Author Posted November 20, 2009 NOW FOR SALE Updated 1st post Will this work in a 2003 car?? Hi mate, i pm'd abbey with the question about swapping ecu's and this was there reply with regards swopping the ECU,s between cars I am sure this will work as the NATS system only tells the ECU to allow the car to start after it says the keys is the right key for the car ( nats box and keys are coded together) Quote
GT4 Zed Posted November 21, 2009 Posted November 21, 2009 it will work and is well priced even if you pay for 1hr fine you maybe quids in NOW FOR SALE Updated 1st post Will this work in a 2003 car?? Hi mate, i pm'd abbey with the question about swapping ecu's and this was there reply with regards swopping the ECU,s between cars I am sure this will work as the NATS system only tells the ECU to allow the car to start after it says the keys is the right key for the car ( nats box and keys are coded together) Quote
