ug45cwb Posted November 4, 2009 Share Posted November 4, 2009 Found some wheels I really like that dont cost £2.5k like the nismos. http://wheeldude.com/gallery2/d/82974-1 ... hancer.jpg I think these are bronze Rota GTRs. Size would be 19x9 and 19x10. Would I need any offset to get the fit? If I just ordered these with tyres fitted could I just bolt them on, job done? Cheers Quote Link to comment Share on other sites More sharing options...
Stew Posted November 4, 2009 Share Posted November 4, 2009 Rarerims can do these I'm sure! Quote Link to comment Share on other sites More sharing options...
cookiemonster Posted November 4, 2009 Share Posted November 4, 2009 Just purchased a set of these myself. They look great. The wheels you outlined are the same as what i have been recommended so the offset should be fne. You can put them straight on but it might be worth getting your wheel allignment done if your changing wheel size. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted November 4, 2009 Share Posted November 4, 2009 You want around a 25mm (or maybe 20mm) offset on them to look great. Make sure whoever does them for you will guarentee that the centre caps will fit on the rear and will refund if they dont. I know loads of people that were told they would fit (inc myself) and they dont due to the clearance on the hub. I run mine with no centre caps which I dont mine, but if you want them on yours make sure you get some kind of guarentee for it Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted November 4, 2009 Share Posted November 4, 2009 You want around a 25mm (or maybe 20mm) offset on them to look great. Make sure whoever does them for you will guarentee that the centre caps will fit on the rear and will refund if they dont. I know loads of people that were told they would fit (inc myself) and they dont due to the clearance on the hub. I run mine with no centre caps which I dont mine, but if you want them on yours make sure you get some kind of guarentee for it What he said i bought some and the buggers wont go on.I might be snapping the pegs off & bonding them on Quote Link to comment Share on other sites More sharing options...
cookiemonster Posted November 4, 2009 Share Posted November 4, 2009 What do you mean by the centre caps fitting Chris? Bit confused Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted November 4, 2009 Share Posted November 4, 2009 He means that they wont go on.Unlike the fronts that fit fine,theres no gap between the hub & the wheel so the pegs cant go anywhere,i broke three pegs off mine,even tried fitting them on the wheel then putting the wheels on but they pop straight out. Im guessing maybe not all of them have this problem though? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted November 4, 2009 Share Posted November 4, 2009 Where the centrecaps go in the middle of the wheel, they have tabs that sit behind the wheel face to hold them in place. When you then offer up the wheel to the hub, the hub is so close to the wheel face there is no space for these locating tabs it pushes them off the wheel and the centre cap wont fit. If you try to fit the centrecap afterwards, you break the tabs. I believe there is a certain offset that will fit properly, but I cant remember what it is. I think it was one of the more agressive offsets (lower number). I showed the problem to someone at Ace Cafe but didnt catch their name. Maybe if they read this they can help me explain Quote Link to comment Share on other sites More sharing options...
cookiemonster Posted November 4, 2009 Share Posted November 4, 2009 oh ok that makes sense. Im getting tyres put on mine in a few weeks so have to look into that a little more. Although they look ok without the centre caps any how. Thanks Quote Link to comment Share on other sites More sharing options...
ug45cwb Posted November 4, 2009 Author Share Posted November 4, 2009 Cheers for the info might be worth getting your wheel allignment done if your changing wheel size Anyone know of anywhere in the Birmingham area that could do this? Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted November 4, 2009 Share Posted November 4, 2009 That reminds me i want mine doing too Quote Link to comment Share on other sites More sharing options...
Chris`I Posted November 4, 2009 Share Posted November 4, 2009 This is the best pic I can find to try and illustrate it. You can see the hole where the centre cap could be. They have lugs that go into the hole and hold onto the back of the wheel face. The problem is the hub comes too far forward to the face of the wheel and wont allow the tab to grip the wheel Looks fine with no centrecap if you paint the bits you can see Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted November 4, 2009 Share Posted November 4, 2009 Just noticed that the part of the lip i thought was coloured is actually the edge,i thought it was the next flat face of the lip that was coloured,thats how im doing mine anyway Quote Link to comment Share on other sites More sharing options...
Chris`I Posted November 4, 2009 Share Posted November 4, 2009 Time Attack style is always to color the very outer lip red Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted November 4, 2009 Share Posted November 4, 2009 Cool beans,im going green with mine to match my calipers now ive got the paint Quote Link to comment Share on other sites More sharing options...
