AlexZ Posted March 20, 2010 Author Share Posted March 20, 2010 Evening guys...with all this talk of MP3's been wired into our standard Bose head units I wanted some action myself. I bought the two parts required from Maplins for a little over £10...bargain. These are the parts I choose to use but everyone has there own options and tools... Tape £3.49 http://www.maplin.co.uk/Module.aspx?Mod ... 7&DOY=20m3 Cable £7.99 3m Stereo Plug to Plug Lead http://www.maplin.co.uk/Module.aspx?ModuleNo=11422 Ok with the parts bought I set about taking the h/u out. This is the first time I've done this but most Jap cars are the same Head Unit I unscrewed the gear knob and pull the surround up and backwards. Uncliped the white ribon from the heater control unit. Unscrewed the to lower screw which retian the centre console Removeed the four lowest screw from under the white box...this lossened the white box and lower section of centre console. Opened the cubby hole and removed the rubber lower mate Removed the two small black screws, then moved onto the two that retain the centre console down the sides. Ok with a little power you should be able to pull the hole centre console outwards. All the cables were still attached to the top three dials and the head unit. I unplugged the top dials, theres a white plug on the drivers side, press and release. With the dials unplugged I had a little more space the remove the head unit cables. With all the cables lose either remove the head unit with the brackets attacked or remove the head unit from the bracket via the four screw on each side like I did. Thats the hard section over, hit the house or garage for wormth and TEA... With the head unit in front of me I released the plastic tap which hold the front face panel on.. Flip the little puppy upside down and removed the following screws...bare in mind most are different lenghts etc...keep each side,back,front in different piles. Underside Back Both sides Front With all the screws removed I flip the bottom cover off. I found the tape beck section needed...tooke out the four retaining screws. The unit will then just pull up and out. With the tape section out and on the bench I got the 3.5 to 3.5 cable and cut it in the middle. I bought this size incase I got it wrong lol...I have two chances with this cable. Each audio cable is wrapped in the earth/ground, I joined both the earth together then tinned all three wire to make the soldering part easier. Lined them up and got to work. I then wrapped a small cable tie around the lead and board so it didnt pull away if caught. Slot the tape section back in the head unit and refixed the four screws. I popped a little insulation tape over the three wire just incase it touches anything. I lead the cable out via the lower section on the back of the head unit. Put it all back together and you should have this Got the new tape and whipped the screws out. Removed all the tape and bobbins then put it back together. I took the centre console and chose a way to make the hole in the cubby slot allow the 3.5mm jack through. I used the solder iron with the cutting blade. Time to reassemble, lead the cable through the hole in the dash and through into the cubby hole. I forgot to take a image of this but you cant miss it lol...I would advise plugging the head unit in, slotting the tape in and trying it before rebuilding it all. Once all built up it looks like this Job done. Quote Link to comment Share on other sites More sharing options...
ZedJohn Posted March 20, 2010 Share Posted March 20, 2010 Spot on! possibly the best solution to the age old Bose issue! How much to do mine? Quote Link to comment Share on other sites More sharing options...
Husky Posted March 20, 2010 Share Posted March 20, 2010 is this the same method posted yesterday by sparky350z? viewtopic.php?f=9&t=33982&start=30 Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 20, 2010 Author Share Posted March 20, 2010 is this the same method posted yesterday by sparky350z?viewtopic.php?f=9&t=33982&start=30 As stated at the top of my post I have only done what others have. I may have put a little more detial into mine. The thread also shows the full job not just head unit.. Zedjohn, there is a chap called R35 LEE I think who offers his services...If your close to me I dont mind helpping you out, but I dont expect payment it only take 30mins lol... Quote Link to comment Share on other sites More sharing options...
Husky Posted March 20, 2010 Share Posted March 20, 2010 is this the same method posted yesterday by sparky350z?viewtopic.php?f=9&t=33982&start=30 As stated at the top of my post I have only done what others have. I may have put a little more detial into mine. The thread also shows the full job not just head unit.. good stuff! this seems a great solution working for more than one Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 20, 2010 Author Share Posted March 20, 2010 defo mate and for £10 you would be silly not to do it if you fancy the MP3 player option in the car . Quote Link to comment Share on other sites More sharing options...
bounty78 Posted March 21, 2010 Share Posted March 21, 2010 Nice work mate Could tell you are very handy with DIY stuffs. So will this allow you to control your iPod or MP3 player tracks from the head unit or steering like u do with the CD multichanger player? Or do u still have to change the tracks/songs using the mp3 player. Quote Link to comment Share on other sites More sharing options...
neo Posted March 21, 2010 Share Posted March 21, 2010 Nice work mate Could tell you are very handy with DIY stuffs. So will this allow you to control your iPod or MP3 player tracks from the head unit or steering like u do with the CD multichanger player? Or do u still have to change the tracks/songs using the mp3 player. you'd still have to use the mp3 player to play and control your tracks, just think of this mod like a pair of headphones, the sound comes out of the unit but the mp3 player still controls the songs. hope that makes sense Quote Link to comment Share on other sites More sharing options...
bounty78 Posted March 21, 2010 Share Posted March 21, 2010 Thanks Neo..i think i will stick to my iPod transmitter as i am not a very technical person..don't want things to go tits up. Quote Link to comment Share on other sites More sharing options...
Hamster Posted March 21, 2010 Share Posted March 21, 2010 Nice work Alex - Top write us as always! Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 21, 2010 Author Share Posted March 21, 2010 Thanks Neo..i think i will stick to my iPod transmitter as i am not a very technical person..don't want things to go tits up. You can control the volume through the steering wheel.. its just the tracks you have to change manually mate. I think this is the same with all after market phono lead conversions. You can buy the Nissan wiring loom for a little over £60 plus vat iirc, I saw this on another memeber thread and I would image that will allow the full control via the wheel Alex Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 21, 2010 Author Share Posted March 21, 2010 Nice work Alex - Top write us as always! Thanks dude, I have a spare lead with plug if you fancy it in yours, only take about half hour to do and its a long trip to the Ring dude lol. :thumbs Quote Link to comment Share on other sites More sharing options...
Hamster Posted March 21, 2010 Share Posted March 21, 2010 Cheers mate, I may take you up on that... I can see my Barbie Girl CD getting a little tedius...... I could always swap it for mitch's Cliff Richard one haha Quote Link to comment Share on other sites More sharing options...
bounty78 Posted March 21, 2010 Share Posted March 21, 2010 Thanks Neo..i think i will stick to my iPod transmitter as i am not a very technical person..don't want things to go tits up. You can control the volume through the steering wheel.. its just the tracks you have to change manually mate. I think this is the same with all after market phono lead conversions. You can buy the Nissan wiring loom for a little over £60 plus vat iirc, I saw this on another memeber thread and I would image that will allow the full control via the wheel Alex It's a shame really as my last car BMW 325i SE hardtop has an iPOD lead/wiring loom and i could actually change the tracks on my steering wheel control. And i could also see the track titles and songs thru the iDrive navigation system. Missed my old car in this weather now that the sun's out but the Zed is a lot more fun..lots of raw power and noice. Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 21, 2010 Author Share Posted March 21, 2010 Cheers mate, I may take you up on that... I can see my Barbie Girl CD getting a little tedius...... I could always swap it for mitch's Cliff Richard one haha No worries dude just name the time...can I borrow that Barbie cd please Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 21, 2010 Author Share Posted March 21, 2010 Thanks Neo..i think i will stick to my iPod transmitter as i am not a very technical person..don't want things to go tits up. You can control the volume through the steering wheel.. its just the tracks you have to change manually mate. I think this is the same with all after market phono lead conversions. You can buy the Nissan wiring loom for a little over £60 plus vat iirc, I saw this on another memeber thread and I would image that will allow the full control via the wheel Alex It's a shame really as my last car BMW 325i SE hardtop has an iPOD lead/wiring loom and i could actually change the tracks on my steering wheel control. And i could also see the track titles and songs thru the iDrive navigation system. Missed my old car in this weather now that the sun's out but the Zed is a lot more fun..lots of raw power and noice. Yeh my girlfriend has a new Honda Civic and that does the same...if you pay Nissans prices I'm sure theres will allow full functions. The mod Ive done cost £10 lol...I happy just using the mp3 player and volume. Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 22, 2010 Author Share Posted March 22, 2010 Afternoon guys, with the day off work and some nasty damage on my front bumper corners courtsey of the old owner I thought it would be a good time to clean them up a little. I'm not to worried about it been perfect but I would like it a little less noticeable. I can only think she must have caught it on a curb or speed bump Any ways, this is what I did..I also fitted my PIAA side light LED bulbs... I started by removing the front bumper, this is the first time I've done this...it's not to bad just a pian in the ass with all the clips... I jacked the drivers side up to gain better accses to the wing liners. Remove the front clips and screw under the wheel arch, then all the screws along the front of the bumper and three down each side of the engine shield. On each side of the front bumper theres two bolts. These hold the front of the wing liner in place. With these bolts removed you can pull the liner around to find the last two clips. The clips hold the back lower section to the engine under shield I think... You should now be able to remove the front section fo the liner. With the liner out the way theres three bolts on each side holding the bumper corners to the wings and headlamps. Finally flip the bonnet release..Remove the 6 retaining clips along the top of the bumper...You only have to pull the insert out a few mm, if you pull to hard they dont remove. With the bumper lose you will have to unclip the washer pipe that feed the headlamp washers. Just push the round clips and they pull off. And shes off. On with the repairs and paint lol. This is what the old owner has left me for a present. I just rubber the rough plastic back with a bit of sand paper and got to work with the primer. Primer Flatted Primer Paint Finsihed, not great but a lot better if you ask me. Side Lights (LED's) While waiting for the paint to dry I changed my side light bulbs..I bought some PIAA ones for my old Celica and thought I might aswell sling them in the Z. With the arch liner out its easy to see what your doing...Just unscrew the side light plug. Couple of images for you all. Thats it done...I used the Nissan touch up on the bumper, it does dry darked when it's fully dry, Quote Link to comment Share on other sites More sharing options...
Hamster Posted March 22, 2010 Share Posted March 22, 2010 ha ha! is there anything you haven't taken apart yet? Quote Link to comment Share on other sites More sharing options...
kazman Posted March 22, 2010 Share Posted March 22, 2010 Really impressive progress. I wish i had your motivation and ability (i suspect having the ability increases motivation levels mind). Quote Link to comment Share on other sites More sharing options...
bounty78 Posted March 22, 2010 Share Posted March 22, 2010 Nice write up and pictures as always Alex ..if only i am good with the technical sides of cars..all your guides in here would have been really useful to me Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 22, 2010 Author Share Posted March 22, 2010 ha ha! is there anything you haven't taken apart yet? Dude, I've only touched what I've had to lol...Just want it as nice as possible and best it can be Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 22, 2010 Author Share Posted March 22, 2010 Really impressive progress. I wish i had your motivation and ability (i suspect having the ability increases motivation levels mind). I dont like to let things linger if possible, the main thing keeping me back with the bumper corners was weather. The forecast was ok today and I had enough time so it got sorted. Its all just nuts and bolts, have a bash it's not hard Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 22, 2010 Author Share Posted March 22, 2010 Nice write up and pictures as always Alex ..if only i am good with the technical sides of cars..all your guides in here would have been really useful to me Bounty, you just have to try it. Once you have done a couple of thing you will be a whizz... Think of all the money you could save, and the satisfaction of knowing you havent been arsed raped by the local garage. Quote Link to comment Share on other sites More sharing options...
bounty78 Posted March 22, 2010 Share Posted March 22, 2010 I have changed the wipers and number plate and interior light bulbs myself. Anything more than that is outside my comfort zone. That's why i haven't put my name down for the folding mirror..not keen on DIY with the wiring diagrams and microswitch..don't want things to go tits up Quote Link to comment Share on other sites More sharing options...
AlexZ Posted March 22, 2010 Author Share Posted March 22, 2010 Thats fair play mate, to be honest my brother has shown me the wiring diagram he's made and I honestly don't have a clue what its showing and I helped him do my car. As for bumper's, centre consoles etc there only bolts...you just have to try it. Quote Link to comment Share on other sites More sharing options...
