vagmag Posted October 31, 2009 Share Posted October 31, 2009 Well it is time I think to change the OEM viscous LSD. Maybe it does not work propetly any more... maybe it never did... The options are the following. Cusco RS Carbonetic LSD OS GIKEN Nismo Quaife (very good choice, lifetime warranty but does not work when the one wheel leaves the ground). Do you have any positive and negative for the above? My use will be most road use, I want to oversteer easier ane always, but I really would not like the sounds that some of the LSDs make. Waiting your opinion and experience. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted October 31, 2009 Share Posted October 31, 2009 If the only desired outcome is more oversteer, then either switch the TCS off or dial in some toe out on the rear. Lot cheaper than changing the diff. Quote Link to comment Share on other sites More sharing options...
Steady Zeddy Posted October 31, 2009 Share Posted October 31, 2009 My Zed is in getting a Kaaz 2way (converted to 1.5way for road) diff fitted at the moment. Its not about oversteer per se - its about more controllable oversteer and getting traction/grip down in and out of corners. IMHO the standard viscous diff is rubbish - at least it was in my last two Zeds. It may be down to it loosing its effectiveness over a couple of years but it certainly wasn't up to putting down the 400BHP/360Ibft on my present Zed on either 1/4 mile or track. The diff shouldn't be particularly noisy if the backlash is set-up correctly and broken-in properly. Regular diff oil changes with the correct oil will also help here. If its clunking/whining excessively then backlash is either too loose/too tight. If you are going for road use then a 1.5way diff will be most suitable. I wouldn't personally want anymore than an 60-80% lock up either - something to keep in mind when setting up the diff. Quote Link to comment Share on other sites More sharing options...
Adam@Z1auto.com Posted October 31, 2009 Share Posted October 31, 2009 the Quaife is your best bet given the conditions you'll be using the car Quote Link to comment Share on other sites More sharing options...
Steady Zeddy Posted October 31, 2009 Share Posted October 31, 2009 the Quaife is your best bet given the conditions you'll be using the car Adam - if you were doing a few track days/1.4 miles per year combined with some road work what diff would you go with? Quote Link to comment Share on other sites More sharing options...
Adam@Z1auto.com Posted November 1, 2009 Share Posted November 1, 2009 If the track days will be on street tires and not r compounds, then the Quaife would still be high on the list. The other good option is the OS Giken. Quote Link to comment Share on other sites More sharing options...
