flirt Posted July 23, 2006 Share Posted July 23, 2006 anything i should know or look out for cheers Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted July 23, 2006 Share Posted July 23, 2006 1. The clips in the wheel arch surrounds are a bit fiddly 2. Note on removal how the surrounds, liners and bodywork match up to ensure you can get them back together. I will send you a PM Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted July 23, 2006 Share Posted July 23, 2006 Myself and Mike have changed these by going in from the top (i.e. no wheel arch removal) But... It is VERY fiddly, and likely to cut your knuckles (if you have large fingers like mine) and/or it will make you swear .... a lot. Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted July 23, 2006 Share Posted July 23, 2006 Thanks guys..... Another mod to the list Quote Link to comment Share on other sites More sharing options...
Trog Posted July 23, 2006 Share Posted July 23, 2006 As mentioned - go in through the top. It is fiddly, but a lot less hastle. Just remove the one bolt holding the light in place and this will give you about 6mm more room to squeeze your fingers in! Quote Link to comment Share on other sites More sharing options...
Jacko Posted July 24, 2006 Share Posted July 24, 2006 As mentioned - go in through the top. It is fiddly, but a lot less hastle. Just remove the one bolt holding the light in place and this will give you about 6mm more room to squeeze your fingers in! Yep, thats the way I did it as well. Much less hassle....... just undo, then you can always use some needle nose pliers to help ease the holder the right way around....... Quote Link to comment Share on other sites More sharing options...
flirt Posted July 24, 2006 Author Share Posted July 24, 2006 success, the joys of having long fingers!!! (note to the ladies) shame the bulbs they sold me didnt fit! ha ha Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 24, 2006 Share Posted July 24, 2006 Yes a lot less hassle if you go through the Top. You'll find one headlamp indicator bulb is easier than the other. I used a pair of long nose pliers to help hold the cable in attempt to get the bulb out through the top cos of my big fingers. Quote Link to comment Share on other sites More sharing options...
steve_b Posted July 24, 2006 Share Posted July 24, 2006 Same as mikey for me. used long nose pilers. Quote Link to comment Share on other sites More sharing options...
Lyger Posted August 28, 2009 Share Posted August 28, 2009 Important Tip some bulbs dont have a very good locking wedge and can fall out into the headlamp when you go over a bump so put some electrical tape around the base to secure it. Took me hours to fish the bulb out. Quote Link to comment Share on other sites More sharing options...
scottsoulby Posted August 28, 2009 Share Posted August 28, 2009 ive had to read this thread a few times now thanks to liam's Z avatar, keep losing concentration Quote Link to comment Share on other sites More sharing options...
jub Posted November 20, 2009 Share Posted November 20, 2009 Yes a lot less hassle if you go through the Top. You'll find one headlamp indicator bulb is easier than the other. I used a pair of long nose pliers to help hold the cable in attempt to get the bulb out through the top cos of my big fingers. Yup, Mike's right. I found that the driver side headlight gave less room when unscrewing the bolt. Quote Link to comment Share on other sites More sharing options...
