ade2009 Posted October 28, 2009 Share Posted October 28, 2009 Here is the report on the 350Z I had done.. There are some off putting issues. Such as an oil leak and corrison of exhuast pipe.. Also some body work blemishes.. I don't think this would be a good buy.. Any comments welcome.. Thanks.. Vehicle details: General Information: Vehicle identification number: V5/Registration document available: MOT certificate available: MOT Expiry date: Vehicle excise expiry date: Mileage Reading: Start of inspection: End of inspection: Lighting: Weather: Ramp available: Summary Report: Contact details: Home: Work: Mobile: Inspection time: NISSAN 350Z - SILVER 28-10-2009 Alexander David Motor Company Kings Road Ascot Berkshire SL5 7BT Make/Model/Colour: PM JN1GAAZ33U0007032 Yes Yes 27/5/10 35,492 31/12/09 37,664 miles 37,673 miles Sunny Dry No Essential & advisable repairs required - not suitable for purchase unless all essential repairs are undertaken and advisable repairs, if any are planned and budgeted for Key for points in following sections S Satisfactory for age and recorded mileage -- Could not be checked X Essential repair requiring immediate attention A Advisable repair should be budgeted for prior to purchase N/A Not applicable Y Yes Page 2 of 9 Inspection Report 28/10/2009 17:17 N No Bodywork Exterior: Please note: Right = Off side (O/S) and Left = Near side (N/S) as viewed from the driver's seat. Minor blemishes, which are acceptable fair wear and tear for the vehicle's age, recorded mileage and type, are not recorded and you should satisfy yourself in this regard. Whist checking the vehicle structure, this inspection has not looked closely at the bodywork/paintwork as this type inspection is designed for someone who is comfortable with the cosmetic appearance of the vehicle. Therefore any purchasers should satisfy themselves in this respect. Evidence of bodywork repair: Yes Bodywork clean and dry: Yes Comments: The overall bodywork condition is satisfactory for its age and mileage, a number of cosmetic blemishes were noted but not of a serious nature. There is no evidence of any major structural accident damage repairs, only minor restoration and paintwork refurbishment along the right bodyside, the repair standard of finish is satisfactory. This inspection has not looked closely at the bodywork/paintwork; you should ensure that the cosmetic appearance is acceptable to you. It was noted that the chassis identification number VIN tags are fitted to all panelwork indicating original panels. Body Exterior: Glass: Body panels: Corrosion: Fuel filler cover/cap: Bonnet hinges: Engine Compartment: Engine Type: Number of cylinders: Coolant level/condition: Turbo/supercharger: Clutch fluid: Antifreeze*: Accelerator linkage: Engine oil level: Hoses/pipes: Fast idle (cold): Engine mountings: not visible water pump Excess fumes/smoke: Petrol 6 S Body damage: No S Door locks/operation: S No Bonnet catch: S S Mud flaps: N/A S S Power steering oil level: S N/A Coolant leaks: No S Fuel pump/pipes: S S Brake fluid: S S Radiator/cap: S X Cold starting: S S External leaks (upper engine): No S Drive Belts: S S Noise level (cold): S -- fuel injection S No Page 3 of 9 Inspection Report 28/10/2009 17:17 Note -To ensure future serviceability, it is important that the engine camshaft belt, also known as a timing belt (if fitted) is replaced at intervals specified by the manufacturer. It is in your best interests you ensure that this is carried out. * Antifreeze only has a 2/3 year life span and requires its strength adjusting after this time or replacing as per manufacturers specifications. Turbocharger (if fitted), if this has been assessed as being satisfactory (S). This relates to its performance only, please note that on many vehicles this unit is hidden by shields/covers and potential oil leaks may not be visible. If the unit or its associated pipes are leaking oil, this will be recorded as oil leaks elsewhere Engine numbers are not checked. Electrical / Controls Starting system/ignition lock: S Controls/switches: S Battery voltages normal: 12.5 S Battery voltages charging: 14.1 S Instruments: S Stop lights: S Indicator/hazard lights: S Reverse/fog lights: S Auxiliary lights S Headlights S Sidelights/running lights: S Battery condition: S Battery voltages starting: 9.8 S Rear & number plate lights: S Battery voltages: S Horn: S Windows/sun roof: S Wipers/washers: S Headlamp wash/wipe S Interior/panel lights S Note - Air conditioning system (if fitted) - This must be used frequently throughout the year including winter months in order to help prevent unit failure and gas leakage. A/C systems require annual servicing. Ensure that this has been carried out in the past. You are advised to have the system serviced prior to purchase if no recent servicing has been undertaken. We are unable to verify dash panel light and switch back lighting operation due to the daylight conditions. Please note that electrical components listed above are assessed by switching them "on or off" only. Accuracy of instruments cannot be assessed. The battery performance and charging system have been tested, but you should note that older batteries can fail gradually or instantly without prior warning. A typical battery service life is 3 to 5 years depending on usage. Battery life cannot be predicted. It is important to check if the airbags and seat belt pre-tensioners (if fitted) are due for specialist checking or replacement. This may vary, but replacement at 10 years is sometimes necessary. Please consult the vehicle handbook or contact the Manufacturers. Interior: Number of seats: Seat adjustment: Boot/tailgate lock: Rear/parcel shelf/load cover: 2 S Internal mirrors: S S Seatbelts: S N/A Front Suspension / Steering / Under Frame: Engine underside leakage: Yes Sub-frames/mountings: S Springs/suspension units: S Steering rack/box: S Tie bars/anti roll bars: S Dampers (condition/leaks): S Power steering (operation): S Wheel hubs/bearings: S Steering & ball joints: S Suspension arms/mountings: A Pipes/hoses: S Chassis members: S Corrosion - floor/chassis: No Gaiters: S Page 4 of 9 Inspection Report 28/10/2009 17:17 Rear Suspension / Under Frame: Springs/suspension bars: Sub-frames/mountings: Bump stops/gaiters: Dampers/bushes: Corrosion - floor/chassis: Pipes/hoses: Clutch / Transmission: Clutch/transmission type: Number of gears: Fluid/oil leaks: Backlash: Mountings: Hydraulic system: Propshaft(s)/fittings: Universal/sliding joints: Exhaust System: Manifold: Pipes: Catalytic converter(s): System condition: Manual 6 S Location rods/fixings: S A Anti roll bar: S S Chassis members: S S Wheel hubs/bearings: S No Suspension arms/fixings: S S No Casings: S S Cables/adjustments: S S Gaitors: S S Drive shaft assembly: S S Linkage (wear): S S Bearings/supports: S S Silencer: S A Heat shields/mountings: S S Joints/couplings: S Limited life The exhaust has been identified as having a limited life because, although there is no leakage present, there is some external corrosion present. The inside of the system may also be corroding but this cannot be inspected internally. Catalytic Converter. If this has been assessed as being satisfactory (S). This relates to confirming its external condition, gas tightness and security. The engineer is unable to confirm its internal condition or effectiveness as this requires exhaust emissions testing, which is beyond the scope of this inspection. Fuel System: Tank: Evidence of leaks: Breather pipes: S S Fuel lines: S No Tank fixings: S Brakes: Master cylinder security: Handbrake op/adjustment: Pipes/connections: S Flexible hoses: S S Fluid leaks: No S Handbrake mechanism(s): S Page 5 of 9 Inspection Report 28/10/2009 17:17 Servo/power system: S Discs/s (if visible): Pedal & pad/linkage: S -- Note - If the vehicle is fitted with brake drums the internal parts including linings are not visible. Brake fluid should be replaced at the manufacturers specifed intervals. Brakes can be effective even when badly worn. As the road wheels are not removed during this inspection, an accurate measurement of the linings, drums, discs and pads cannot be given. Therefore, it is advised that the road wheels be removed and a general brake wear and serviceability check be carried out prior to purchase. Ensure all components are within manufacturer's wear specification and replace any worn or badly corroded parts. Wheels & Tyres: Wheel type: Alloy It is recommended tyres are replaced when the tread depth reaches 2mm. If uneven tyre wear is noted, this may indicate incorrect geometry, which can result in excessive and rapid tyre wear. A full steering and geometry check is therefore recommended. Wheel rims: Wheel trims: Tyres: Front RH: Front LH: Rear LH: Rear RH: Spare: S N/A Min tread depth: 7mm S 7mm S 7mm S 7mm S 3mm S It is not possible to comment whether the tyres fitted to this car are the actual tyre specifications as recommended by the manufacturer. Road Test: The road test has been undertaken within the speed limits and prevailing traffic conditions in the locality of the inspection. If a road test has not been carried out, please refer to the engineer's comments page. Test distance: 9 miles Speed achieved up to: 70 mph Final drive operation/noise: S Road holding/stability: S Clutch operation**: S Engine performance: S Footbrake operation: S Steering effort: S Excess smoke: No Suspension noise: No Warning lights: S Instrument/control function: S Gearbox operation/noise: S General steering/handling: S Cooling fan operation: S Engine noise: S Hand/park brake operation: S Hot restarting: S Overheating evidence: No Auto changes/kick-down: N/A ** It should be carefully noted that the life expectancy of clutches is uncertain and difficult to predict, being dependant on owners driving style, vehicle operation and terrain. The fact that the clutch has not been identified as faulty/slipping/juddering/noisy on the report does not and should not be taken to imply that the clutch assembly will have a continuing life expectancy from the time of our check. They can begin to slip at any time. Recall Notices h Page 6 of 9 Inspection Report 28/10/2009 17:17 You are advised to check if this vehicle is or has been due a Manufacturer’s safety recall, please Please note that only the items listed above have been checked. That means that on this type of vehicle many costly items, fittings, equipment and systems have not been checked or tested. The client must satisfy him/herself in this respect and check that all others items work to the client's satisfaction prior to purchase. Final Check: Oil leaks: Yes Coolant leaks: No Uneven tyre wear: No Vehicle documents & inspection environment notes: Registration document (V5): The V5/Registration document shows 1 previous keeper(s), the last change of keeper on 9/7/07 Security: The engineer recommends that relevant spare and service keys are obtained prior to purchase. MOT: MOT date is satisfactory, no further action is required. Servicing: - full service history not checked The service history seen, indicated that the last recorded service was carried out on the 24/4/08 at 29,061 miles. Therefore the engineer would suggest a full service and brake check to the manufacturer's recommendations prior to purchase, which may reveal further defects not apparent at this examination. Inspection conditions notes: No vehicle hoist/ramp was available at the time of the inspection. A large trolley jack and stands were used in order to carry out underside checks. This limits the view of the underside. Some areas could not be fully seen. There may be further defects, which may be visible given clear access and view. Advice, warnings and recommendations: The overall assessment shows this vehicle to be in a condition commensurate with its age and mileage. Despite the adverse comments, the vehicle overall is a satisfactory example of the model and providing the repairs and recommendations are carried out, the vehicle should be capable of continued service, given regular maintenance and repairs when required. However, the issues noted in the report should be made the subject of any agreement with the vendor where appropriate, and attended to as necessary. The exhaust system is showing normal service corrosion, review condition at service intervals. Exhaust emissions, using gas analysing equipment, does not form part of the inspection service, so no accurate analysis of the fueling performance can be given. Page 7 of 9 Inspection Report 28/10/2009 17:17 The steering-suspension mountings and bushes show normal service wear consistent with usage. Our reporting is based on the same standard as an MOT test, which allows for a degree of normal wear and deterioration, but not to excess. The extent of wear is not considered excessive at this juncture and unlikely to attract MOT failure. However, if service criteria is applied a garage may advise replacement of bushes or mountings at a future service interval and this should be planned for as found necessary. No steering alignment or geometry checks are carried out as part of this inspection. Regular servicing and maintenance is recommended to ensure continued reliability. It is essential that after the purchase of this vehicle, all under bonnet fluid levels are checked on a regular basis and monitored. Although the radio operates the full functionality and performance of the in-car entertainment system has not been checked. All electrical items have been checked by switching on and off only. The vehicles instruments and gauges have been observed for operation, but their accuracy cannot be verified. Also the “standard†vehicle warning lights were checked and functioned normally during test. Specialized equipment systems and warning lights are not tested. The air conditioning is working and cools the air output down to the correct level. However, air conditioning systems require periodic servicing and this should be planned for when necessary. The underside of this vehicle is fitted with protective under trays and inner wing casings, which has restricted inspection of the lower parts of the engine and transmission and some areas of the understructure. This does inhibit visual examination of auxiliary components and some oil or fluid leakage might not be revealed. This factor is outside the control of the engineer. Brakes may be effective even when worn. As road wheels are not removed during the inspection, measurement of pads, linings, discs and non-visible components cannot be assessed. Unless a recent brake service has been carried out, it is advised that a general brake wear and serviceability inspection is carried out to ensure all components are within manufacturers wear specification. This includes brake fluid renewal inline with the manufacturer’s recommendations, usually every 2 years. This should be planned for as part of general maintenance. Although still serviceable, there is normal service wear in the clutch assembly consistent with its usage, but the condition can only be assessed by test driving. There is adequate engine braking on change down and no slipping or judder evident under normal driving conditions. However, the life expectancy of clutch units is uncertain and no prediction of the future service life can be given. During the 9 mile road test the vehicles handling, braking operation, transmission function and general performance was considered to be satisfactory with no adverse symptoms or noise levels. If you have not viewed or driven the vehicle personally, you must satisfy yourself of the vehicle’s cosmetic appearance, specification and suitability for your needs and expectations by viewing and driving the vehicle yourself, prior to making your purchasing decision. Check with vendor the warranty entitlement on this car. It is advised that you consider some form of Warranty be sought or purchased for this vehicle as additional protection against unexpected future repairs, ensuring that the level of cover is suitable for your needs and the vehicle specification. Essential Repairs: It is strongly advised that the essential repairs are investigated and rectified prior to purchase. Engine oil level - The engine oil level registers on the minimum mark, top up and monitor consumption. Service - No recent service documentation was seen with this vehicle. Therefore the engineer would recommend a service and brake inspection is planned for. This may reveal further defects and service requirements not apparent at this examination. Additional consumable parts will also have to be renewed as found necessary. Engine underside leakage - Heavy oil contamination around undertray sump area. Remove undertray clean off oil contamination and identify source of leakage, review and attend to as necessary. Advisable Repairs: These should be planned and budgeted for. Page 8 of 9 Inspection Report 28/10/2009 17:17 Suspension arms/mountings - There is normal service wear deterioration evident in steering-suspension mountings, bushes, and ball joints, consistent with usage but not to excess. Sub-frame/mountings - There is a light incidence of surface rusting on some underbody metal components including, suspension, sub-frames, brake and transmission units, this is consistent with climatic conditions and not detrimental. As a measure of preventative maintenance the areas should be cleaned off, and treated with an oil-based product. Exhaust Pipes - The rear exhaust system is heavily corroded, review condition and plan for replacement as necessary. Quote Link to comment Share on other sites More sharing options...
u2---- Posted October 28, 2009 Share Posted October 28, 2009 All your personal details are on the links ade2009! I would edit them if I were you mate. Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 28, 2009 Author Share Posted October 28, 2009 Oh blimey.. i thought I had done that.. Thanks.. Quote Link to comment Share on other sites More sharing options...
IanS16 Posted October 28, 2009 Share Posted October 28, 2009 Who compiled that report? Its pretty damn thorough Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 28, 2009 Author Share Posted October 28, 2009 Just an AA bloke..lol I just spoke to him on the phone.. He said"The oil leak issue is just some oil oil on the under try, he told the garage to get it steamed cleaned then check it for any leaks.." He said" the paintwork looks good to the naked eye, but has has some work on it due to sufrace scrtaches, however the bodywork has no dents and has no sign of accident damage.." He told me"it drives very well no clutch wear which could be a problem if the car had been driven hard" Overall he said"It's a fine example as long as the oil leak and exhualst linkage corrosion issues are adreesed before purchase." I have been in touch with the garge and he said he would adress the issues and give the car a service.. so if he keeps to his word I thnk I'll try and do a deal.. Quote Link to comment Share on other sites More sharing options...
nixy Posted October 28, 2009 Share Posted October 28, 2009 i think sometimes the throroughness of these reports scares you more than anything. I would say it sounds ok. Its a bit like when you get a full structural survey on a house you are buying - scares the life out of you but is usually pretty normal! Quote Link to comment Share on other sites More sharing options...
bounty78 Posted October 28, 2009 Share Posted October 28, 2009 How much did it set you back to get an AA report just out of interest? Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 28, 2009 Author Share Posted October 28, 2009 How much did it set you back to get an AA report just out of interest? £159.. not to bad i have to say.. a lot cheaper than anyone else i found, including RAC and I have membership of RAC.. Quote Link to comment Share on other sites More sharing options...
bounty78 Posted October 28, 2009 Share Posted October 28, 2009 That's a very thorough report. Won't worry too much about the corroded exhaust system as long as they are replacing it. I think that seems to be a very common problem with lots of Zed. A lot of people here end up replacing it with an aftermarket one. Quote Link to comment Share on other sites More sharing options...
Martin W Posted October 28, 2009 Share Posted October 28, 2009 Oh blimey..i thought I had done that.. Thanks.. Its still there! Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 28, 2009 Author Share Posted October 28, 2009 That's a very thorough report. Won't worry too much about the corroded exhaust system as long as they are replacing it. I think that seems to be a very common problem with lots of Zed. A lot of people here end up replacing it with an aftermarket one. Thanks.. So you think its worth going for then?? Quote Link to comment Share on other sites More sharing options...
bounty78 Posted October 28, 2009 Share Posted October 28, 2009 I am afraid it's something you have to decide for yourself. My opinion is purely on the exhaust system because i had similar problem with mine and some of the used one on sale on ebay seems to be slightly corroded externally. Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted October 28, 2009 Share Posted October 28, 2009 Did you feel like a kid in a candy shop when you took it for a test drive ? Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 29, 2009 Author Share Posted October 29, 2009 Did you feel like a kid in a candy shop when you took it for a test drive ? Oh yeah i did Quote Link to comment Share on other sites More sharing options...
rich5259 Posted October 29, 2009 Share Posted October 29, 2009 Oh blimey..i thought I had done that.. Thanks.. Its still there! you still didn't get rid of the link Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 29, 2009 Author Share Posted October 29, 2009 Oh blimey..i thought I had done that.. Thanks.. Its still there! you still didn't get rid of the link Thanks Hopfuly I have now.. Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 29, 2009 Author Share Posted October 29, 2009 Yes It's all in place now. I'm going on Monday should be there in the afternoon. Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted October 29, 2009 Share Posted October 29, 2009 Did you feel like a kid in a candy shop when you took it for a test drive ? Oh yeah i did Then buy buy buy Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 29, 2009 Author Share Posted October 29, 2009 Did you feel like a kid in a candy shop when you took it for a test drive ? Oh yeah i did Then buy buy buy i am am am.. Good thing with the car being in Ascot and me being in south Derrbyshire, it will give me time to get the know the car right away.. Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted October 29, 2009 Share Posted October 29, 2009 Where abouts in S Derbyshire?? Im in Oakwood Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 29, 2009 Author Share Posted October 29, 2009 Where abouts in S Derbyshire?? Im in Oakwood Swadlincote.. Or to the locals.. Swad.. Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted October 29, 2009 Share Posted October 29, 2009 Where abouts in S Derbyshire?? Im in Oakwood Swadlincote.. Or to the locals.. Swad.. Oh well, someone has to live there I suppose.. Least they have got a dry ski slope Quote Link to comment Share on other sites More sharing options...
ade2009 Posted October 29, 2009 Author Share Posted October 29, 2009 Where abouts in S Derbyshire?? Im in Oakwood Swadlincote.. Or to the locals.. Swad.. Oh well, someone has to live there I suppose.. Least they have got a dry ski slope Makes a change that someone has heard of it.. It does have some lovley card shops as well.. Quote Link to comment Share on other sites More sharing options...
