3FIDDYZ Posted October 27, 2009 Share Posted October 27, 2009 Nismo S-Tune suspension Nismo front ARB Product Description Engineered for the enthusiast that drives on the street. These parts feature credible, measured increases in performance and an additional feature that the aftermarket can't touch. - Lowers vehicle by 20mm - Spring rate and damping force tuned specifically for this model - Provides improved steering response - Precise bolt-on installation - Reduces body lean, pitch, and dive - Provides Neutral, balanced handling ARB's Specifications: Hollow Steel Tube Construction (1.4" ) Front Bars Decrease Body Roll Improve Handling Hard Rubber Busings Inlcluded These items are found on the 350z NISMO edition and are very suitable for "Spirited" Road Use and are more than happy on the track. SOLD Quote Link to comment Share on other sites More sharing options...
mc Posted October 27, 2009 Share Posted October 27, 2009 How many miles have these done? do you need a rear camber kit for a 20mm drop? and where are you based? Quote Link to comment Share on other sites More sharing options...
IanS16 Posted October 27, 2009 Share Posted October 27, 2009 Good price Quote Link to comment Share on other sites More sharing options...
dcash5 Posted October 27, 2009 Share Posted October 27, 2009 Hard to tell whether a camber kit would be required as it varies from car to car but as general rule of thumb is anything over an Inch lower would require 'non-standard' highly adjustable camber arms. Working on this assumption a 20mm drop would not require them. Quote Link to comment Share on other sites More sharing options...
rawbhp Posted October 27, 2009 Share Posted October 27, 2009 Just dropped mine on Teins (14mm rear 17mm front) and it was easy to achieve factory adjustments with no extra bits. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted October 27, 2009 Author Share Posted October 27, 2009 How many miles have these done? do you need a rear camber kit for a 20mm drop? and where are you based? Hi, Its got about 8k on it, 10k at the most. Nope no aditional kit was needed for any adjustment. When it was on the car no adjustment needed either but if any is needed it will be through the existing setup. Am in Redhill but happy to meet you somewhere 1/2 way. Mark Quote Link to comment Share on other sites More sharing options...
Rosssco Posted October 27, 2009 Share Posted October 27, 2009 If I was keeping my Zed I'd bite you're hand off - seems like a good upgrade package and given the price of uprated springs, dampers and ARB's, looks to be a very good deal! Quote Link to comment Share on other sites More sharing options...
vagmag Posted October 27, 2009 Share Posted October 27, 2009 you got pm Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted October 27, 2009 Author Share Posted October 27, 2009 you got pm Replied Quote Link to comment Share on other sites More sharing options...
Andy Posted October 27, 2009 Share Posted October 27, 2009 Fantastic bit of kit, am very tempted by these, would make the stance of my Z spot on! Quote Link to comment Share on other sites More sharing options...
bhavin85 Posted October 27, 2009 Share Posted October 27, 2009 mark, where these fitted to the zed when you came to woking? if they were the stance looks perfect with these on! I just got a set of eibachs otherwise id probably be very interested! bump for a good seller Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted October 27, 2009 Author Share Posted October 27, 2009 Sell the eibachs then mate and feel the difference Should be a few ££ in them? Thanks for the bump! Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted October 30, 2009 Author Share Posted October 30, 2009 SOLD Quote Link to comment Share on other sites More sharing options...
