Andrew Posted July 21, 2006 Share Posted July 21, 2006 Sorry folks - probably easy answer but in handbook it just says refer to dealer and can only see items on forum about oil itself. Where the h*ll is the oil FILTER?! How do you change it?! Thanks very much Andrew Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted July 21, 2006 Share Posted July 21, 2006 Once you get the car up on stands and remove the undertray, you'll see it right enough It should only be hand-tightened and so a filter wrench is unlikely to be required (and don't use one to tighten the new one on either) This might also be useful http://www.350z-uk.com/forum/viewtopic ... ght=manual Quote Link to comment Share on other sites More sharing options...
