introspect Posted October 22, 2009 Share Posted October 22, 2009 Had my front pads changed with some Ferodo DS2500 on Tuesday. Drove home and everything seemed fine. Just been out now and when I'm driving I'm getting a metallic grinding/whining noise. It doesn't happen when I'm braking, only when I'm driving along. Anyone got any suggestions as to what could be causing this? I'm going to phone the garage that did them for me tomorrow morning, but I'm a bit worried at the moment Quote Link to comment Share on other sites More sharing options...
stanski Posted October 22, 2009 Share Posted October 22, 2009 Had similar sometimes you get foreign matter trapped between disc and dust sheild.But since you had brakes done maybe a clip has come loose or the pad cracked? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 22, 2009 Share Posted October 22, 2009 Suspect that the back plate may now be touching the disc. Back to the garage for rectification. Quote Link to comment Share on other sites More sharing options...
introspect Posted October 22, 2009 Author Share Posted October 22, 2009 Suspect that the back plate may now be touching the disc. Back to the garage for rectification. Is it likely to have caused any damage to the disk? Will I be ok driving it if that's the case? I'm a bit worried about making things worse Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 22, 2009 Share Posted October 22, 2009 Suspect that the back plate may now be touching the disc. Back to the garage for rectification. Is it likely to have caused any damage to the disk? Will I be ok driving it if that's the case? I'm a bit worried about making things worse It will be fine to just drive back to the garage. Quote Link to comment Share on other sites More sharing options...
introspect Posted October 22, 2009 Author Share Posted October 22, 2009 Thanks for the info Alex, much appreciated Quote Link to comment Share on other sites More sharing options...
