How much Filter Oil to use?
jerry3167
Guys,
Im about to replace my JWT Filter element with a clean, new fresh one, how much oil is needed to coat it, and do you need to put oil through the front hole along the pleats?
Cheers
Jerry :)
Not much or you will mess up the MAF sensor :)
Put oil along all pleats, including those at the front/top. Depending on what oil kit you have, if its the same as the K&N, just spray down the pleats, making sure each one gets some oil. Do not go around and around, only make one pass. Remember that one spray will do multiple pleats. I suggest you do a test spray onto some paper so that you know how wide the spray pattern is :thumbs:
If you think you have over oiled it, wash it off and start again. Recharge kit is cheap, MAFs are not ;)
Yes you have to do those pleats too Jerry, they are still part of the cotton filter as well :thumbs:
Actually it makes sense to do them as the hole is facing the intake pipe, so naturally air would get in more so from there ;)
:scare: But if the air goes straight in surely, it doesnt get filtered? :surrender:
